How to see what ISIS routes im receiving when OSPF is preferred?
graham smart
How can I see what routes are being sent to me via one routing protocol when another is being prefered?
For example.
I have both OSPF and IS-IS running.
When OSPF is preffered ISIS routes dont appear in a "sh ip route isis"
I can see the OSPF ones in a normal sh ip route or a sh ip route ospf
When i change OSPF's AD to 200 so ISIS is preferred. I can see them in a sh ip route and sh ip route isis however a show ip route ospf now shows nothing.
Essentially I want to be able to see what routes im getting from both OSPF and ISIS ( even though ospf would be prefferred? )
Any ideas?
-Graham
Please note: My comments are simply suggestions. I cannot be held liable for any loss of data, life or marbles due to following my instructions.
Got a website? Need some live chat software?
cadet alain
show ip ospf database
show isis database
Alain
6 Replies 6
cadet alain
show isis database
Alain
Hi Thanks,
Is there a way to show it like an ip route output?
Id like to easyily compare routing tables from OSPF to ISIS to ensure they both have the same routes..
I can see a show isis datbase verbose | inc IP is half meaningful but comparing to OSPF is tricky..
-Graham
what do you mean by that ?
Alain
Im trying to compare routes recieved by each protocol.
Obviously a show ip route only gives whats active in the table. So id like to be able to get a nice comparison of routs learnt but both OSPF and ISIS at a glance.
I fear this isnt going to be possible.
-Graham
AFAIK this is not possible but you can export the 2 outputs and do some regular expression  to get what you need.
Alain
Ok, Thanks. I figured as much
Thanks for your time.
-Graham
