Too much traffic on interface. Link L2 between SW4500-SW6500
mcystylo27
Hi everyone, i hope anyone can help me with a problem of a LINK L2, Between SW4500 and SW6500.
I have experience too much traffic between the link L2 (Fastethernet - GigabitEthernet),, 90%.  What can I do to fix that, any command? rate-limit or something?
Here is some outputs of the interfaces:
FastEthernet2/30 is up, line protocol is up (connected)
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
     reliability 255/255, txload 247/255, rxload 27/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s
  input flow-control is unsupported output flow-control is unsupported
  Last input 00:00:00, output never, output hang never
  Last clearing of "show interface" counters 4w0d
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 10824000 bits/sec, 3091 packets/sec
  5 minute output rate 97251000 bits/sec, 8037 packets/sec
     2689449777 packets input, 1208566367319 bytes, 0 no buffer
     Received 102306260 broadcasts (48742487 multicast)
     6488342448 packets output, 9556099159094 bytes, 0 underruns
     0 lost carrier, 0 no carrier
GigabitEthernet3/3 is up, line protocol is up (connected)
     reliability 255/255, txload 29/255, rxload 248/255
  input flow-control is off, output flow-control is on
  Clock mode is auto
  Last input 00:00:21, output 00:00:37, output hang never
  Last clearing of "show interface" counters 16w1d
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 75413
  30 second input rate 97430000 bits/sec, 8086 packets/sec
  30 second output rate 11558000 bits/sec, 3214 packets/sec
     23652164256 packets input, 34716225186331 bytes, 0 no buffer
     Received 393377785 broadcasts (391598650 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     9618336659 packets output, 4777117555931 bytes, 0 underruns
Thanks for your comments
mfurnival
Level 4
Level 4
Hi Jose,
What is too much traffic? The switches are only forwarding the traffic that they need to forward. If performance is being impacted you can use QoS for prioritization but you need to decide what traffic should get priority.
I noticed that you have fastethernet on one side and gigabit ethernet on the other so the link is only going to run at 100Mb. If you have a gig interface on the other switch use that and your utilization will drop to 1/10 of what it is now.
