How to setup Cisco 890 true webinterface
wesley
I have a Cisco 890 Router. But I lost the setup CD/DVD to configure my Cisco 890. Can somebody tell me
how I can access the webinterface or setup from this router. Or can I somewhere download the software?
Thx
81 Replies 81
It could need java plugin upgrade.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
how do you flash the router to the new CCP version
Kind Regards
Please check this link:
http://www.cisco.com/c/en/us/td/docs/net_mgmt/cisco_configuration_professional_express/v3_2/guides/adminguide/CCP_admin_guide/installing_ccp_express_adminview.pdf
Hope it is useful
I downloaded the lastest file of CCP. I'm a beginner so what do I use to get the files on the router?
I think this link has a very good explanation:
http://www.omnisecu.com/ccna-security/how-to-install-ccp-and-how-to-configure-cisco-router-for-ccp.php
Thx,
but am stuck a community section. They show me something with a CMD window and alot of info like ip and so. But I cannot access the router for that information. I already reset the router
I have not followed the entire thread, but have you tried to access the router with a console cable (the blue cable, if you have that) instead of the web interface ?
I have a console cable its a version with a Usb for the pc and RJ45 connector on the other side
I don't know if that works. Try and connect that to the router console port (I think you have to use the USB port on the router and the RJ-45 for your PC).
You can then use Hyper Terminal to configure the router:
https://communities.cisco.com/thread/63656?start=0&tstart=0
No its Usb on the pc and the RJ45 console input on the router. I have Putty. My Usb Serial port is on COM1. It opens a window and stands still with a green square. Do I have to wait till it repsond?
try a different COM port. Green square usually means you have the wrong COM port. Do you have the COM port configured with the settings Speed 9600 Data Bits 8 Stop Bits 1 Flow Control/Parity None ?
I changed the COM port to 4 our 5. Still the same problem. The setting are like you said
That's the router I have. I resetted the hole thing
what happens when you restart the router with the console port connected to your PC ? Do you see any output at all ?
nothing happens. I don't understand it. I also tryed a DB9 to RJ45 console cable. Same result
