How to setup Cisco 890 true webinterface
wesley
I have a Cisco 890 Router. But I lost the setup CD/DVD to configure my Cisco 890. Can somebody tell me
how I can access the webinterface or setup from this router. Or can I somewhere download the software?
Thx
81 Replies 81
You need to go to Windows device manager, then search the COM ports and if you have the drivers configured properly you will see the COM port (see image 1).
Once you have identify the COM port you can open putty, select Serial and set up the COM port (see image 2).
Please keep us posted.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Julio Moisa,
that is what I do. Here my console cable is on COM3. Then I put the COM port in putty en there it stuck
Thanks, Nothing happens pressing enter keyboard?
I get this now when i press enter
On that picture you are the privileged exec mode, now you can configure the router executing configure terminal
ok thx :-)
1. I want it in DHCP our change the routers ip en sub
2. How to activate wireless connection
If you want to create a DHCP scope you need to configure the following:
Example
ip dhcp pool MYDHCP
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
dns-server 8.8.8.8 4.2.2.2
ip dhcp excluded-address 192.168.10.1
In order to configure wireless on a router 891W, you need to follow this configuration:
http://www.cisco.com/en/US/docs/routers/access/800/880/software/configuration/guide/880_basic_device_wireless_config.html
Ok,
let me explain what i want to do.
1. I want to configure the Cisco Router as a Wireless Access Point
2. I have already a Wireless Modem on cable (here in Belgium it is Telenet)
3. That Telenet modem is on ip 192.168.0.1 (See attachement picture)
4. I have a second Wireless Access Point configured on IP 192.168.0.3
5. The networkcable i will connect will come on NetwerkInferface 0 port
I hope this explains a little bit better what I want to do with it :-)
Kind Regards
issue the command:
show run
and post the output. We can then fill in the necessary bits and pieces...
hereby the pic that I get when running command "show run"
Cisco Configuration Professional (Cisco CP) is installed on this device.
This feature requires the one-time use of the username "cisco" with the
password "cisco". These default credentials have a privilege level of 15.
YOU MUST USE CISCO CP or the CISCO IOS CLI TO CHANGE THESE  PUBLICLY-KNOWN
CREDENTIALS
Here are the Cisco IOS commands.
username <myuser>  privilege 15 secret 0 <mypassword>
no username cisco
Replace <myuser> and <mypassword> with the username and password you want
to use.
IF YOU DO NOT CHANGE THE PUBLICLY-KNOWN CREDENTIALS, YOU WILL NOT BE ABLE
TO LOG INTO THE DEVICE AGAIN AFTER YOU HAVE LOGGED OFF.
For more information about Cisco CP please follow the instructions in the
QUICK START GUIDE for your router or go to http://www.cisco.com/go/ciscocp
User Access Verification
Username: Ncomrouter
Password:
% Password expiration warning.
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
Replace <myuser> and <mypassword> with the username and password you want to
use.
yourname#show running-config
Building configuration...
Current configuration : 5821 bytes
! Last configuration change at 08:54:45 UTC Sun Jun 18 2017 by cisco
version 15.0
hostname yourname
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
service-module wlan-ap 0 bootimage autonomous
yourname#show
yourname#show running config
% Invalid input detected at '^' marker.
version 15.0
hostname yourname
boot-start-marker
boot-end-marker
no aaa new-model
crypto pki trustpoint TP-self-signed-2097789431
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-2097789431
 revocation-check none
 rsakeypair TP-self-signed-2097789431
crypto pki certificate chain TP-self-signed-2097789431
 certificate self-signed 01
  3082024F 308201B8 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32303937 37383934 3331301E 170D3137 30363137 32313438
  35335A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 30393737
  38393433 3130819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100BBCC 2877A414 B4105732 AFA48E9B E05FD1C5 52A5433E 8438AA58 7BE2BAB6
  BC1B8736 E795C345 D4B78B5E 9D29062F 8F35A6B2 3A5A8ECA F6BBD61A 1709B280
  3C0A2B50 F121CC58 FF9BB701 CEFC6E52 C85CDF75 D57FF2B5 4423567C 7590456C
  D0ED7034 D1CE74C0 EB0F69AD 018CF197 3AC682E9 F7A10ACE 3FE96CB0 3A135F6C
  68F50203 010001A3 77307530 0F060355 1D130101 FF040530 030101FF 30220603
  551D1104 1B301982 17796F75 726E616D 652E796F 7572646F 6D61696E 2E636F6D
  301F0603 551D2304 18301680 14F87BA4 934C5CC7 6AD0BCF6 C8709E1E 9F269B46
  2F301D06 03551D0E 04160414 F87BA493 4C5CC76A D0BCF6C8 709E1E9F 269B462F
  300D0609 2A864886 F70D0101 04050003 81810066 68458D96 886C2DFB 7A1B8E55
  BB8160A0 D40CD9D7 C287CA21 A628CAC9 1DF2A4CD D2B19F01 FFB8C9FA 295C7B8D
  E6613DB7 D88DAF73 4D1670C1 8F345D5C B5CBD4F1 B9304EDF 47C32C20 1407846E
  FCF539CF 9BC3E9BA 9AE63CAB B83FF245 0228B640 C9E4FBE5 F42B9216 BAABA1EB
  C9C5081B 3D44D7F7 F7807339 94715C6C AE7B23
        quit
ip source-route
ip dhcp excluded-address 10.10.10.1
ip dhcp pool ccp-pool
   import all
   network 10.10.10.0 255.255.255.248
   default-router 10.10.10.1
   lease 0 2
ip dhcp pool MYDHCP
   network 192.168.0.0 255.255.255.0
ip cef
no ip domain lookup
ip domain name yourdomain.com
no ipv6 cef
license udi pid CISCO892W-AGN-E-K9 sn FCZ1449C36P
username Ncomrouter privilege 15 secret 5 $1$zwxS$06dvG4X/4yU.O6CnlynZI.
interface BRI0
 no ip address
 encapsulation hdlc
 shutdown
 isdn termination multidrop
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0
 no ip address
 shutdown
 duplex auto
 speed auto
interface wlan-ap0
 description Service module interface to manage the embedded AP
 ip unnumbered Vlan1
 arp timeout 0
interface Wlan-GigabitEthernet0
 description Internal switch interface connecting to the embedded AP
interface Vlan1
 description $ETH-SW-LAUNCH$$INTF-INFO-FE 1$
 ip address 10.10.10.1 255.255.255.248
 ip tcp adjust-mss 1452
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
access-list 23 permit 10.10.10.0 0.0.0.7
no cdp run
control-plane
banner exec ^C
this session.
use.
^C
banner login ^C
CREDENTIALS
no username cisco
to use.
^C
line con 0
 login local
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin udptn ssh
line aux 0
line vty 0 4
 access-class 23 in
 privilege level 15
 login local
 transport input telnet ssh
line vty 5 15
 access-class 23 in
 privilege level 15
 login local
scheduler max-task-time 5000
end
Could you please provide a: show version
Thank you in advance.
here you go :-)
CREDENTIALS
no username cisco
to use.
Password:
this session.
use.
yourname#show version
Cisco IOS Software, C890 Software (C890-UNIVERSALK9-M), Version 15.0(1)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Fri 29-Oct-10 00:19 by prod_rel_team
ROM: System Bootstrap, Version 12.4(22r)YB3, RELEASE SOFTWARE (fc1)
yourname uptime is 16 hours, 47 minutes
System image file is "flash:c890-universalk9-mz.150-1.M4.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 892 (MPC8300) processor (revision 1.0) with 498688K/25600K bytes of memory.
Processor board ID FCZ1449C36P
9 FastEthernet interfaces
2 Gigabit Ethernet interfaces
1 ISDN Basic Rate interface
1 terminal line
1 Virtual Private Network (VPN) Module
1 cisco Embedded AP (s)
256K bytes of non-volatile configuration memory.
250880K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO892W-AGN-E-K9    FCZ1449C36P
License Information for 'c890'
    License Level: advipservices   Type: Permanent
    Next reboot license Level: advipservices
Can you post a schematic drawing of your setup including IP addressing ? That would make it easier to make a recommendation...
That said, to be on the safe side, I would configure a different subnet for the Cisco. So, instead of 192.168.0.0/24, use 192.168.2.0/24 for the Cisco. The configuration would look like this:
version 15.0
hostname yourname
boot-start-marker
boot-end-marker
no aaa new-model
quit
ip source-route
ip dhcp excluded-address 192.168.2.1
import all
lease 0 2
ip dhcp pool MYDHCP_WIRELESS
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
ip cef
no ip domain lookup
no ipv6 cef
interface BRI0
no ip address
encapsulation hdlc
shutdown
no ip address
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface wlan-ap0
ip unnumbered Vlan2
arp timeout 0
switchport trunk native vlan 2
switchport mode trunk
interface Vlan1
interface Vlan2
ip address 192.168.2.1 255.255.255.0
ip http server
no cdp run
bridge 1 protocol ieee
bridge 1 route ip
Then, configure the AP Module by typing:
yourname# service-module wlan-ap0 session
and configure the below:
hostname ap
enable secret 5 $1$uoRD$Mz7Q8NVh9L0PYSoIKxghH/
no aaa new-model
dot11 ssid YOURSSID
vlan 2
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 0 cisco123
username cisco privilege 15 secret 5 $1$JbKq$341Z9uDAkeHKcMTO6/WI00
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 2 mode ciphers tkip
ssid YOURSSID
station-role root
interface Dot11Radio0.2
encapsulation dot1Q 2 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
no ip route-cache
interface GigabitEthernet0.2
no ip route-cache
bridge-group 1
interface BVI1
ip address dhcp
no ip route-cache
ip default-gateway 192.168.2.1
ip http server
no ip http secure-server
bridge 1 route ip
I will make a drawing of the setup I now have and will post it here then
Kind Regards
I have Teamviewer installed, I think I need your Partner ID ?
