Clearing Passwords and finding the Break Sequence
I have a 2514 Router that i have tried numerous times to access the break sequence and do a pwd reset, while connected to the console port.. How ever its whopping me good..
Here is the startup print out.
System Bootstrap, Version 5.2(8a), RELEASE SOFTWARE
Copyright (c) 1986-1995 by cisco Systems
2500 processor with 16384 Kbytes of main memory
F3: 3699924+94808+191696 at 0x3000060
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
IOS (tm) 3000 Software (IGS-I-L), Version 11.1(6), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1996 by cisco Systems, Inc.
Compiled Mon 09-Sep-96 13:58 by tej
Image text-base: 0x0301F84C, data-base: 0x00001000
cisco 2500 (68030) processor (revision D) with 16384K/2048K bytes of memory.
Processor board ID 03326348, with hardware revision 00000000
Bridging software.
X.25 software, Version 2.0, NET2, BFE and GOSIP compliant.
2 Ethernet/IEEE 802.3 interfaces.
2 Serial network interfaces.
32K bytes of non-volatile configuration memory.
4096K bytes of processor board System flash (Read ONLY)
Press RETURN to get started!
What am i doing wrong. I am using Tera Term to access the routers interface.
turnera
Based on the info at this link, the break sequence for Terra Term is Alt-b. Is that what you are invoking when you attempt your boot up sequence on the router?
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a0080174a34.shtml
Every time I get the return command and then it boots the old company image on the router.
Check this command, I mean with which IOS image is said to bootup.
boot system flash:
Thanveer
"Everybody is genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is a stupid."
