hsrp config
anitachoi3
I will configure the hsrp for auto failover when one circuit down. Attached file is the hardware installation.
Those are the requirements
- the default circuit is provider B
- default gateway of all users is 192.168.12.10
- when circuit B down, it will failover to provider A, all traffic via circuit A.
- when circuit B comes up again, router B is active, router A is hot standby. All traffic vai circuit B.
I configure router setting, pls check any missing or need to amendy
Any suggestion is welcome
rdgs
R1
interface Fastethernet 0
ip address 192.168.10.1 255.255.255.0
no ip route-cache
no ip proxy-arp
standby 1 ip 192.168.10.10
standby 1 preempt
interface Fastethernet 1
description Provider A, 10M cct
ip address 210.x.x.x 255.255.255.252
R2
ip address 192.168.10.2 255.255.255.0
no ip route-cache
no ip proxy-arp
standby 1 preempt
standby 1 priority 105
standby 1 track Fastethernet 1
description Provider B, 10M cct
ip address 216.x.x.x 255.255.255.252
7 Replies 7
anitachoi3
attachedment
This seems to be quite a working solution.
Few comments:
Just "standby 1 ip" would suffice in R1(Backup) and it will learn the vIP from the primary even if you didn't specify it.(Try and see for yourself).
To protect against HSRP-spoofing you could add HSRP(MD5) authentication.
e.g.
"standby 1 authentication md5 key-string xxxx"
Please check the documentation for additional options.
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t2/feature/guide/gthsrpau.html#wp1027129
ellendrew
HSRP Configuration is correct.
Edison Ortiz
The track will only kick-in when the interface is down/down.
With ethernet WAN that is rare unless the provider shuts their router down causing your router to be hard down.
I suggest using track with SLA and ping a remote interface in order to verify connectivity via that link. Pinging the next hop on that link sounds like a reasonable target.
HTH,
__
Edison.
Hi Edison,
"With ethernet WAN that is rare unless the provider shuts their router down causing your router to be hard down"
I have a question regarding this statement. In practice there are switches sit between the Ethernet WAN connecting routers or gateways, right?
In such situations isn't it just the Ethernet interface of the immediate device which could be effectively tracked/monitored ?
Yes.
The recommendation is monitoring Layer3 reachability instead of the status of the physical link as the physical link does not provide a true indication of remote connectivity.
HTH,
__
Edison.
This is the a good document for 'Static Routing Backup Using Object Tracking'
http://www.cisco.com/en/US/docs/ios/12_3/12_3x/12_3xe/feature/guide/dbackupx.html
