MPLS and ATM connectivity
mirzaakberali
hi ,
Can any one tell me how ATM and MPLS works interms of technolgy.
Few basic diffrences are required and which one is preferred in stablity and cost.
Thanks ,
Akber Mirza.
mirzaakberali
Request some one to responsd.
Thanks ,Akber Mirza.
ATM is now a legagcy technology and it would be best to steer away from that if rolling out new infrastructure.
MPLS over ATM, is a way of running MPLS switching across your exisiting ATM infrastructure, it uses the VPI/VCI ATM cell header to forward MPLS packets through the core instead of using ATM cells natively.
Heres a link to have a look at.
http://www.cisco.com/en/US/tech/tk436/tk798/technologies_tech_note09186a008017492a.shtml
LR
I suggested using frame based MPLS instead of cell based.
essentially, when you configure your VPI/VCI link have it a layer 3 subnet (/30 for example) and then tag switch on the link.
This way you will have a simpler setup, specialy if u wish to migrate top Ethernet later on.
Sam
