HSRP routing issue
aansatosorigin
Basically, I m using two routers, router A and router B. Lease line on router A while ISDN on router B. On production time, only lease line is used as primary route. But, if lease line fails, all traffic will route to router B to trigger the ISDN. Really need all experts here to help on how to create the routing to establish this design. Thank you.
11 Replies 11
Richard Burts
I believe that your requirements can be solved through HSRP and does not require any special routing logic. You will want to configure HSRP on the LAN interfaces. You will want to set priority so that router A with the leased line is the primary/active router and that router B is the standby (I suggest priority of 105 on router A and the default of priority 100 on router B). You will want to configure tracking on router A to track the serial interface. If the serial interface fails then router A will reduce its priority and you want the priority of router B to be higher than router A at this time. You will want to configure HSRP preempt on router B so that it can take over if the priority of router A is lowered. And you will want to configure preempt on router A so that when the leased line recovers that router A can resume as the active router.
If you configure those things I believe that you will satisfy your requirements.
Rick
Rick
Hi Rick,
Thanks so much!!
Pavel Bykov
Level 5
Level 5
You can use Dialer Watch for ISDN.
Sample configuration and more information here:
http://cisco.com/en/US/partner/tech/tk801/tk133/technologies_configuration_example09186a008009455e.shtml
Config watches the routing table and presence of the route in there.
Hi Slidesv,
I cant access the link since it needs an authentication. Really need your help. Thank you.
aansatosorigin,
same url from Slidesv without cco login...
http://www.cisco.com/en/US/tech/tk801/tk133/technologies_configuration_example09186a008009455e.shtml
regards,
Sean khoo
Thanks Sean! Really helps.
mukeshpal
Hi buddy,
we can configure this thing in very simple way. configure the serial interface and for isdn configure BRI interface or creat the dialer and bind the dialer inside the serial interface as a backup line. give delay command. all traffic will go vis serial interface and once lease line will go down it will trigure the isdn to handle the traffic and once lease line will up again Lease line will take up the responsibility.
int s0/0
backup int d1
bacup delay 3 10
hth
regards...Mukesh
Mukesh
If you read the original post the leased line is on router A and the ISDN is on router B. Backup interface will not work when the primary is on one router and the backup is on another router.
Rick
Rick
Danilo Dy
I go with Rick recommendation. I have that setup in a production, works like a charm and no sweat at all. Unless you want to explore a more complicated configuration with dynamic routing, etc..
Dandy
Hi Dandy,
If dont mind, I really2 interested to know how HSRP configuration using dynamic routing.Hope you happy to share. Thank you.
Here is some link.
If both lines in the same router
http://www.cisco.com/warp/public/129/bri-backup-map-watch.html
Each line in different router. I was planning this, until I found a simple setup using HSRP as what Rick recommended. In the LAN, since OSPF is use, it doesn't matter whether you use HSRP or not
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094052.shtml
Troubleshooting Demand Circuit keeps bringing up the link
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a008009481b.shtml
Advantages and disadvantages
http://www.cisco.com/warp/public/123/backup-main.html
Dandy
