HSRP subinterfaces problem
I have configured Router 1 as follows
int gi 0/0.10
encapsulation dot1q 10
ip add 192.168.10.3
standby 10 ip 192.168.10.1
standby 10 preempt
standby 10 priority 115
and Router 2 as
int gi 0/0.10
ip add 192.168.10.2
standby 10 preempt
They are connected via a switch to the LAN segment 192.168.10.0/24
A PC with
IP: 192.168.10.50
subnet: 255.255.255.0
default-gateway: 192.168.10.1
I SIMPLY CANNOT PING 192.168.10.1 from the PC
please help
pings are going from the PC to 192.168.10.2 and 192.168.10.3 but not to 192.168.10.1
the #show standby command displays that the virtual ip is active and well
Please help
Thank you in advance
Yes. It is correct that the last two hex digits should be the group number (0A for group 10).
At least we know do know why the ping from the PC is failing. The PC did an arp and the MAC address that it is working with is not the correct MAC. I believe that this incorrect MAC is a result of packet tracer not working correctly.
Rick
Rick
15 Replies 15
Richard Burts
Please post the output of show standby and of show cdp neighbor from both routers. Perhaps that will provide some insight into the cause of the problem.
Rick
Rick
I have uploaded the sh standby details below
the topology is working in GNS3 but not in packet tracer
Dennis Mink
Can you ping the real IP addresses at all?  i.e. the .3 and/or .2?
Please remember to rate useful posts, by clicking on the stars below.
yes i can ping the real addresses
I am attaching the show standby output
GigabitEthernet0/0.10 - Group 10 (version 2)
  State is Active
    4 state changes, last state change 00:04:00
  Virtual IP address is 192.168.10.1
  Active virtual MAC address is 0000.0C9F.0000
    Local virtual MAC address is 0000.0C9F.F00A (v2 default)
  Hello time 3 sec, hold time 10 sec
    Next hello sent in 0.395 secs
  Preemption disabled
  Active router is local
  Standby router is 192.168.10.2
  Priority 100 (default 100)
  Group name is hsrp--10 (default)
GigabitEthernet0/0.20 - Group 20 (version 2)
  State is Active
    5 state changes, last state change 00:03:49
  Virtual IP address is 192.168.20.1
    Local virtual MAC address is 0000.0C9F.F014 (v2 default)
    Next hello sent in 0.498 secs
  Preemption disabled
  Standby router is 192.168.20.2
  Group name is hsrp--20 (default)
I can see two strange things in your output:
State is Active
Preemption disabled
If you configured
int gi 0/0.10
ip add 192.168.10.3
standby 10 preempt
then
a) preemtion should not be disabled,
b) priority should be 115
What is the subnet mask you configured on the interface?
Milan
Is this output from GNS or Packet tracer. If this is from packet tracer, are you sure that HSRP is supported?
https://learningnetwork.cisco.com/thread/14322
Also vMACs do not seem to be correct, vMAC for HSRP should start 0000.0c07.acXX
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
The references to support for HSRP in packet tracer are quite interesting and support my theory that this problem is really about packet tracer and not about HSRP.
Also if you read the output carefully it clearly says that the device is running HSRPv2
0000.0c07.acXX is the format for version 1 and not for version 2.
Rick
Rick
I too couldn't help but notice this anomaly
i have two very different outputs from GNS3 and packet tracer
this one is of packet tracer
GNS3 is working fine
HSRP is supported in packet tracer but works with single interfaces, but in case of sub-interfaces i do see a problem
Hello Blau, in the Beta version (version 6.0 beta) there is now support for HSRP. They made this available in the Cisco Academy recently (couple of months now) - although its still 'buggy' in my opinion.
My old tutor told me they're trying to make it good enough for CCNP studies and their students, so expect more enhancements for the lucky ones
It may/will become better than GNS (one day) in my view, purely because of the switch's and switching capabilities/configuration, wheras GNS, we'll be limited by the limitations of NM16-ESW module and other factors.
(sorry to have posted off topic)
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
While I might agree that these changes are probably good (it is more the way that I would typically configure HSRP) I do not see either the priority setting (or defaulting) and the lack of preemption as things that could cause a PC to not be able to ping the virtual address. So I would suggest that these changes are optional things that the original poster can consider.
I find a statement from the original poster in an earlier post to be very interesting:
This suggests to me that the problem really is in the way that packet tracer attempts simulate the operation of routers and switches and not so much is a configuration problem.
If we are going to continue to look for some problem other than a fault in packet tracer then I would like to see two things:
- I have asked before to see the output of show cdp neighbor. I believe that this would help us to be sure of the layer 2 relationships.
- I would like the original poster to test again ping from the PC to the virtual address and then to post the output of arp -a (or whatever is the equivalent command on that OS to display the PC arp table). I would like to know if the PC has received a response when it arped and if so what MAC it is using to get to the virtual address.
Rick
Rick
Hi Rick,
I was not suggesting any changes, just pointed out the discrepancy between the configuration shown in the origianl post and the show command outputs sent later.
I agree it might be a packet tracer probelm probably.
Best regards,
Milan
Milan
I interpreted your post as suggesting that the original poster make the changes. I missed the fact that the original post did show a configured priority and configured preempt. So you made a good catch that there is a discrepancy between the how output and the original post of configuration. Sorry that I did not correctly understand your post.
And ultimately I do believe that the problem is the failure of an emulator to actually do HSRP.
Rick
Rick
I reconfigured and restarted the devices in packet tracer
the show cdp of both the devices are are correct
Device ID    Local Intrfce   Holdtme    Capability   Platform    Port ID
Switch       Gig 0/0          140            S       2960        Fas 0/1
Switch       Gig 0/0          124            S       2960        Fas 0/2
the new show standby is
  State is Active
    5 state changes, last state change 00:00:27
    Next hello sent in 2.474 secs
  Preemption enabled
  Priority 115 (configured 115)
  State is Active
    4 state changes, last state change 00:00:19
    Next hello sent in 2.499 secs
  Preemption enabled
but the pings still continue to fail
the arp -a on the virtual pc shows a mac address of
0000.0C9F.0000 associated with 192.168.20.1
and this is incorrect as the virtual mac address should be having the group number as the last two hexadecimal characters
right?
right?
