HSRP track rtr state not working?
jcmattos1
We have dual 2851's with 12.4(9)T1 on both ends over MPLS the inside sub-interfaces are configured with HSRP groups and track rtr state. We notice upon icmp failover that the rtr state changes to down and the priority decrements to 95 from 105. Below the standby which is at default at 100. But it doesnt failover? Any ideas?
RTR1
track 5 rtr 15
interface GigabitEthernet0/0
description INSIDE INTERFACE
no ip address
duplex full
speed 1000
interface GigabitEthernet0/0.2
description MANAGEMENT VLAN
encapsulation dot1Q 2
ip address 172.29.2.4 255.255.255.0
standby version 2
standby 2 ip 172.29.2.1
standby 2 priority 105
standby 2 preempt
standby 2 authentication md5 key-chain KEY
standby 2 name MANAGEMENT
standby 2 track 5 decrement 10
interface GigabitEthernet0/0.4
description VOIP VLAN
encapsulation dot1Q 4
ip address 172.29.4.4 255.255.255.0
standby version 2
standby 4 ip 172.29.4.1
standby 4 priority 105
standby 4 preempt
standby 4 authentication md5 key-chain KEY
standby 4 name VOIP
standby 4 track 5 decrement 10
service-policy input VOIP-IN
interface GigabitEthernet0/0.5
description LAN1 VLAN
encapsulation dot1Q 5
ip address 172.29.5.4 255.255.255.0
standby version 2
standby 5 ip 172.29.5.1
standby 5 priority 105
standby 5 preempt
standby 5 authentication md5 key-chain KEY
standby 5 name LAN1
standby 5 track 5 decrement 10
ip sla 15
icmp-echo 172.24.70.11 source-ip 172.29.2.4
frequency 5
ip sla schedule 15 life forever start-time now
RTR2
track 5 rtr 15
no ip address
duplex full
speed 1000
ip address 172.29.2.6 255.255.255.0
standby version 2
standby 2 preempt
ip address 172.29.4.6 255.255.255.0
standby version 2
standby 4 preempt
standby 4 name VOIP
ip address 172.29.5.6 255.255.255.0
standby version 2
standby 5 preempt
standby 5 name LAN1
ip sla 15
icmp-echo 172.24.70.12 source-ip 172.29.2.6
frequency 5
6 Replies 6
royalblues
Level 10
Level 10
Can you post a sh standby from both the routers?
Also will it be possible to run a debug standby and shut down a link to get some log events
Narayan
Edison Ortiz
Both HSRPs are tracking the same SLA and they are both decrementing 10. As you reported when the track reports down, the HSRP with priority 105 goes down to 95 but the 'standby failover' also decrements from 100 to 90 since it has the same track.
If you want the standby failover to take over with priority 100, you must remove the track from RTR2's interfaces.
Thx Edison! They appear identical, but they are using different source/dest IP's. Upon failover the HSRP standby router indicates tracking Up state and priority 100. But still no failover between the two. Thanks for the help though, anything else I could try?
What does the 'show standby' status on RTR1 show as the local priority and the RTR2's (standby router) priority when the RTR1's tracked object is down? Or can you post the output of show standby from RTR1 when it's tracked object is down.
Sundar
Have you verified the authentication between the HSRP routers is working correctly ?
Let us see the 'show stand' output from each device.
Just for kicks, I tried changing the HSRP versions back to 1 and surprisingly it worked like a charm. Very strange, thx guys for all your help!
