HTTPS Access
WerllenSilva
Hello everyone,
I configured ip http secure server to test https access to my router.
I can access from the web browser, but when I try to telnet from the router to interfaces within it the session does not close. I would like to know if anyone has had this problem, if there might be a bug or i'm forgetting some configuration.
Even though it works using the web browser, I need to test it using a non routed interface, so I'm checking to see if there might be a problem.
HTTP secure server status: Enabled
HTTP secure server port: 443
HTTP secure server ciphersuite: XXXX
HTTP secure server TLS version: TLSv1.2 TLSv1.1
HTTP secure server client authentication: Disabled
HTTP secure server PIV authentication: Disabled
HTTP secure server PIV authorization only: Disabled
HTTP secure server trustpoint: XXXX
HTTP secure server peer validation trustpoint:
HTTP secure server ECDHE curve: XXXX
HTTP secure server active session modules: ALL
Loopback IP (not routed)
telnet 192.168.10.168 443
Trying 192.168.10.168, 443 ...
% Connection timed out; remote host not responding
As I`m doing a telnet from the router itself, I think that the vty acl is not used.
Cisco 9400 Series
@WerllenSilva Hi, can you share the configuration of the router which have the HTTP server enabled? there can be many reasons. for start,, check if you have any ACLS to block HTTP traffic to mentioned port.
Good luck
KB
M02@rt37
Hello @WerllenSilva
By default, the HTTPS service binds to all interfaces. If you haven’t restricted it, it should already be listening on the loopback...
Do yo check c9400 logs ?
Best regards
WerllenSilva
Hey everyone,
I was able to schedule a reboot for the device and now is working fine.
One point I noticed is that after the reboot, a new trustpoint certificate was generated, I cannot confirm that this was the problem but now is working fine.
Thank you everyone for your help.
