Hub Support in DMVPN, Key Server in Get VPN
zohaib.shabir
Does ASR 1000 Series support DMVPN Hub, and Key Server in GETVPN.
Laurent Aubert
DMVPN is supported but not KS for GETVPN.
Please note sharing the tunnel protection among several tunnel interface is not implemented even if you can configure it.
Laurent.
Hello Laurent,
On some of the documents ASR Key Server Support is told to be on the Roadmap, is there any update as when will ASR be Key Server supported?
Also is there any sizing or scalability document that can be used for designing Getvpn using ISRG2s, also the design guide mentions ISRs, and ISRG2s will be included in the next version of the Design Guide,
