HWIC-1ADSL Problems - Cisco 1841
andy.dodd
Hi Guys,
I am a bit confused over this one, maybe one of you can help me.
I have a Cisco 1841, which I use for my home router using the WIC-1ADSL card this worked fine. My line has now been updated to a 21CN line, so I have access to a ADSL2+ connection. To access the ADSL2+ service I have been using a little Netgear, just to tie me over till the HWIC-1ADSL card arrived.
Now here is the problem:
Cisco 1841 + WIC-1ADSL - Sync fine, ATM Status up, Internet Access
Cisco 1841 + HWIC-1ADSL - Sync fine, ATM Status down/up/down etc.., No Internet Access
IOS Version: c1841-advipservicesk9-mz.151-3.T
Has anyone else come across this kind of behaviour, on a Cisco device? I have read a few threads on HWIC firmware not getting on with some IOS versions.
I was going to try running a older IOS to see if this helps or a firmware upgrade on the card.
Or is the card faulty?
Current Running Config.
Cisco1841#show run
Building configuration...
Current configuration : 2582 bytes
! Last configuration change at 21:48:23 GMT Wed Jun 29 2011
version 15.1
hostname Cisco1841
boot-start-marker
boot-end-marker
enable password
no aaa new-model
clock timezone GMT 0 0
clock summer-time GMT recurring last Sun Mar 1:00 last Sun Oct 2:00
dot11 syslog
ip source-route
ip dhcp excluded-address 192.168.0.1 192.168.0.10
ip dhcp excluded-address 192.168.1.254
ip dhcp excluded-address 192.168.0.254
ip dhcp pool Wired_Range
   import all
   network 192.168.0.0 255.255.255.0
   default-router 192.168.0.254
   dns-server 212.23.3.100 212.23.6.100
   lease 4
ip dhcp pool Wireless_Range
   import all
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.254
   lease 4
ip cef
ip domain name home.local
ip name-server 212.23.3.100
ip name-server 212.23.6.100
no ipv6 cef
interface FastEthernet0/0
description Wired Local Network
ip address 192.168.0.254 255.255.255.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface FastEthernet0/1
description Wireless Internal Network
ip address 192.168.1.254 255.255.255.0
ip nat inside
duplex auto
speed auto
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
pvc 0/38
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface Dialer0
description DSL Connection
mtu 1492
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname username
ppp chap password 0 password
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 50 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
logging esm config
access-list 50 permit 192.0.0.0 0.255.255.255
dialer-list 1 protocol ip permit
control-plane
banner motd ^C
You are attempting to connect to a managed device
If you are not an authorised user DISCONNECT IMMEDIATELY
^C
line con 0
logging synchronous
line aux 0
line vty 0 4
logging synchronous
login local
transport input ssh
scheduler allocate 20000 1000
end
Show ATM
Cisco1841#int atm0/0/0
ATM0/0/0 is down, line protocol is down
  Hardware is HWIC-DSLSAR (with Alcatel ADSL Module), address is 001f.6ca2.5d1c (bia 001f.6ca2.5d1c)
  MTU 4470 bytes, sub MTU 4470, BW 448 Kbit/sec, DLY 1140 usec,
     reliability 123/255, txload 1/255, rxload 1/255
  Encapsulation ATM, loopback not set
  Keepalive not supported
  Encapsulation(s): AAL5
  23 maximum active VCs, 256 VCs per VP, 0 current VCCs
  VC Auto Creation Disabled.
  VC idle disconnect time: 300 seconds
  Last input never, output 00:00:18, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 47
  Queueing strategy: Per VC Queueing
     107 packets input, 7638 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     149 packets output, 5990 bytes, 0 underruns
     0 unknown protocol drops
Cisco1841#show int atm0/0/0
ATM0/0/0 is up, line protocol is up
     reliability 129/255, txload 1/255, rxload 1/255
  Last input never, output 00:01:13, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 51
     152 packets output, 6050 bytes, 0 underruns
Show DSL
Cisco1841#show int dsl int atm 0/0/0
ATM0/0/0
Alcatel 20190 chipset information
                     ATU-R (DS)                              ATU-C (US)
Modem Status:           Showtime (DMTDSL_SHOWTIME)
DSL Mode:           ITU G.992.5 (ADSL2+) Annex A
ITU STD NUM:            0x03                                         0x3
Chip Vendor ID:           'STMI'                                         'TSTC'
Chip Vendor Specific:  0x0000                               0x0510
Chip Vendor Country:   0x0F                               0xB5
Modem Vendor ID: 'CSCO'                                         'TSTC'
Modem Vendor Specific: 0x0000                               0x5100
Modem Vendor Country:  0xB5                               0xB5
Serial Number Near:    FOC13370P5KCISCO73993206
Serial Number Far:  Chip ID:            C196 (0)
DFE BOM:           DFE3.0 Annex A (1)
Capacity Used:           97%                                         34%
Noise Margin:           -2.5 dB                               23.0 dB
Output Power:           20.0 dBm                               12.0 dBm
Attenuation:           31.0 dB                               14.0 dB
FEC ES Errors:           10                                         7650
ES Errors:           11                                         12391
SES Errors:           11                                         1149
LOSES Errors:            2                                         1829866
UES Errors:            0                                         1831146
Defect Status:                     LCD       LOM          LOF  LCD
Last Fail Code:           None
Watchdog Counter: 0x76
Watchdog Resets: 0
Selftest Result: 0x00
Subfunction:           0x00
Interrupts:           41549 (0 spurious)
PHY Access Err:           0
Activations:           34
LED Status:           OFF
LED On Time:           0
LED Off Time:           0
Init FW:           init_AMR-4.0.015_no_bist.bin
Operation FW:           AMR-4.0.015.bin
FW Source:           embedded
FW Version:           4.0.15
                      DS Channel1            DS Channel0          US Channel1            US Channel0
Speed (kbps):                    0                  9530                   0                   448
DS User cells:                    0                     1
US User & Idle cells:                                                  0                 17256
Reed-Solomon EC:          0                   399                   0                 45634
CRC Errors:                    0                   407                   0                 62813
Header Errors:                    0                     1                   0                174882
Total BER:                      0E-0                     65535E-255
Leakage Average BER:            0E-0                     65535E-255
Not able to get Interleave delay information since the training
log collection is going on. Turn off the training log collection
or wait for few seconds till the log collection is completed.
Bitswap:                 enabled                      enabled
LOM Monitoring : Disabled
DMT Bits Per Bin
Not able to collect DMT bin information since the training
DSL: Training log buffer capability is not enabled
WIC-1ADSL
Cisco1841#show dsl int atm 0/0/0
ATM0/0/0
Alcatel 20150 chipset information
DSL Mode:        ITU G.992.1 (G.DMT) Annex A
ITU STD NUM:     0x01                            0x1
Vendor ID:       '    '                          'TSTC'
Vendor Specific: 0xDBB0                          0x0510
Vendor Country:  0x04                            0xB5
Capacity Used:   99%                             56%
Noise Margin:    10.5 dB                         20.0 dB
Attenuation:     30.0 dB                         16.5 dB
FEC ES Errors:    0                               0
ES Errors:        0                               0
SES Errors:       0                               0
LOSES Errors:     0                               0
UES Errors:       0                               0
Defect Status:   None                            None
Watchdog Counter: 0x56
Watchdog Resets: 0
Subfunction:     0x15
Interrupts:      1327 (0 spurious)
PHY Access Err:  0
Activations:     1
LED Status:      ON
LED On Time:     100
LED Off Time:    100
Init FW:         ASW_init_3_8_131.bin
Operation FW:    ASW_R3_8_131.bin
FW Source:       embedded
FW Version:      3.8.131
                 Interleave             Fast    Interleave              Fast
Speed (kbps):          6144                0           448                 0
DS User cells:       158587                0
US User & Idle cells:                                344951                0
Reed-Solomon EC:          0                0             0                 0
CRC Errors:               0                0             0                 0
Header Errors:            0                0             0                 0
Bit Errors:               0                0
BER Valid sec:            0                0
BER Invalid sec:          0                0
DMT Bits Per Bin
000: 0 0 0 0 0 0 0 2 2 3 5 7 7 7 7 7
010: 8 8 8 7 7 8 7 6 6 6 5 4 4 5 0 0
020: 0 0 0 0 0 0 8 8 8 9 9 A A A A B
030: B B B B B B B B B B B B 2 B B B
040: 0 B B A A A A A A A A A A A A A
050: A A A A A A A A A A A A A A A A
060: A A A A A A A A A A A A A 9 A A
070: 9 9 9 9 9 9 9 9 9 9 8 9 9 8 9 9
080: 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8
090: 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8
0A0: 8 8 8 8 8 8 8 7 8 8 8 7 8 8 7 7
0B0: 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7
0C0: 7 7 7 6 7 7 6 7 7 7 7 6 6 7 6 6
0D0: 6 6 6 5 6 6 7 6 7 6 7 6 6 6 6 6
0E0: 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 5
0F0: 5 4 4 4 2 0 0 0 0 0 0 0 0 0 0 0
Cisco1841# show dia
Cisco1841# show da
Cisco1841# show dia
Cisco1841# show atm
Cisco1841# show atm 0/0/0
% Invalid input detected at '^' marker.
Cisco1841#show int atm 0/0/0
  Hardware is DSLSAR (with Alcatel ADSL Module), address is 001f.6ca2.5d1c (bia 001f.6ca2.5d1c)
     reliability 193/255, txload 1/255, rxload 59/255
  Encapsulation(s): AAL5 AAL2
  23 maximum active VCs, 256 VCs per VP, 1 current VCCs
  Last input never, output 00:00:01, output hang never
     6021 packets input, 7387757 bytes, 0 no buffer
     4197 packets output, 1041558 bytes, 0 underruns
Cisco1841# show int dai
Cisco1841# show int dia
Cisco1841# show int dialer 0
Dialer0 is up, line protocol is up (spoofing)
  Hardware is Unknown
  Description: DSL Connection
  Internet address is 82.69.X.X/32
  MTU 1492 bytes, BW 56 Kbit/sec, DLY 20000 usec,
     reliability 255/255, txload 1/255, rxload 255/255
  Encapsulation PPP, LCP Closed, loopback not set
  Keepalive set (10 sec)
  DTR is pulsed for 1 seconds on reset
  Interface is bound to Vi2
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 00:06:44
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 7
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/0/16 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 42 kilobits/sec
     5980 packets input, 7362934 bytes
     4192 packets output, 1024913 bytes
Bound to:
Virtual-Access2 is up, line protocol is up
  Hardware is Virtual Access interface
  MTU 1492 bytes, BW 448 Kbit/sec, DLY 20000 usec,
     reliability 255/255, txload 1/255, rxload 55/255
  Encapsulation PPP, LCP Open
  Stopped: CDPCP
  Open: IPCP
  PPPoATM vaccess, cloned from Dialer0
  Vaccess status 0x44
  Bound to ATM0/0/0 VCD: 1, VPI: 0, VCI: 38, loopback not set
  DTR is pulsed for 5 seconds on reset
  Interface is bound to Di0 (Encapsulation PPP)
  Last input 00:00:08, output never, output hang never
  Last clearing of "show interface" counters 00:06:20
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     6024 packets input, 7364381 bytes, 0 no buffer
     4202 packets output, 1025101 bytes, 0 underruns
     0 carrier transitions
Cisco1841#
paolo bevilacqua
You need to upgrate ADSL firmware. To download it, you will need a support contract.
Sorry about the delayed reply, using the new firmware has made no difference. For reference its 4.0.18 I tested. I have swapped the HWIC card out for a normal ADSL modem which is working fine now.
Well I have been facing the same problem with different version of IOS in 2811 router. So I have restored the old version of IOS then waited for the new version of IOS. cisco introduced 15.1.4M which isstable. you can upgrade to this verison.
serblander
I also have problem with HWIC, its just lost connection. It was workning fine but now it can not establish connection to ISP.
Here are HWIC info and router info:
router#sh dsl int ?
  ATM  ATM interface
  |    Output modifiers
router#sh dsl int
ATM0/0/0
Line not activated: displaying cached data from last activation
Modem Status:    Showtime (DMTDSL_DO_OPEN)
Vendor ID:       '    '                          'BDCM'
Vendor Specific: 0xDBB0                          0x6193
Capacity Used:   83%                             94%
Noise Margin:    13.0 dB                          6.0 dB
Attenuation:     19.5 dB                          9.0 dB
Defect Status:                  LCDi         None
Last Fail Code:  Handshake or init message invalid or had bad CRC
Watchdog Counter: 0x89
Watchdog Resets: 0
Subfunction:     0x15
Interrupts:      2879 (0 spurious)
PHY Access Err:  0
Activations:     16
LED Status:      OFF
LED On Time:     100
LED Off Time:    100
FW Source:       embedded
FW Version:      3.8.131
Speed (kbps):          8160                0           960                 0
Cells:                    0                0           813                 0
CRC Errors:               0                0             0                 0
Bit Errors:               0                0
BER Valid sec:            0                0
DMT Bits Per Bin
000: 0 0 0 0 0 0 0 5 8 A B B B C D D
010: D D D D D D D C C B B B B B 0 0
020: 0 0 0 0 0 0 6 7 8 8 9 9 A A A B
030: B B B B B C C C C C C C C B B C
040: B C C B C C B B C C C C C C C C
050: C C C C C C C C C C C C C C C 2
060: C C C B C C B B B B B B B B B B
070: B B B B B B B B B B B B B B B B
080: B B B B B B B B B B A A B A A B
090: A B B B A A A A A A A A A A A A
0A0: A A A A A A A A A A A A A A A A
0B0: A A A A 9 9 A 9 9 9 9 9 9 9 9 9
0C0: 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9
0D0: 9 9 9 9 9 9 8 8 8 8 8 8 8 8 8 8
0E0: 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8
0F0: 8 8 8 8 8 8 7 7 7 7 7 6 6 6 5 5
On same line other adsl router works but not HWIC.
