After erasing the startup-config on a 2811 router, I am unable to get past the "Would you like to enter the initial configuration dialog?" prompt.
None of the key strokes issued from my PC have any effect.
I have:
Tried using a different console cable
Tried using a different PC (Both XP pro)
Changed the hyperterm settings (baud rate,stop bits - all of them)
Turned on the "echo typed characters"
Turned on "Send line ends with line feeds"
Used a different term application.
None of this has had any effect. Any ideas?
