i can't get connected to internet on my pc, but my router can
Dear All
Today i have installed a new 1921 Cisco Router, i want to connect my isp modem to one of the gigabit port at the router, and then my pc to the other gigabit port.
i have configured my pc ip statically to be in the same range of the gigabit port 0/1
the isp modem port is in the same range of the gigabit port 0/0
the network is like this
PC (192.168.1.5)  ==> router port 0/1 (192.168.1.1)
isp modem (192.168.100.1) ==> router port 0/0 (192.168.100.4)
i have configured the NAT, so my pc now is natted to forward the traffic to port 0/0
after all this, now i can ping the isp modem, and i can even enter the GUI page of the ISP modem, but i dont have internet connection.
from the router, i can ping both far interfaces, and i can even ping google.com or 8.8.8.8 so my router is connected to internet.
i tried to pull out the cable from the router and plugged it directly to the modem and after modifying the ip of the PC, i am able to connect to internet.
maybe i am missing something here, please help me.
the Show IP interface breaf is:
SJ_Router#sh ip in br
Interface                                                    IP-Address      OK?           Method Status                Protocol
Embedded-Service-Engine0/0            unassigned      YES          NVRAM  administratively down down
GigabitEthernet0/0                               192.168.100.4   YES         NVRAM  up                    up
GigabitEthernet0/1                                  192.168.1.1     YES         NVRAM  up                    up
NVI0                                                         192.168.100.4   YES            unset  up                    up
this is the sh run-conf print out
hostname SJ_Router
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
ip cef
ip dhcp excluded-address 192.168.1.1 192.168.1.10
ip dhcp pool "SJM_DHCP_Pool"
ip dhcp pool SJM_DHCP_Pool
network 192.168.1.0 255.255.255.0
default-router 192.168.100.1
dns-server 8.8.8.8
ip domain name yourdomain.com
no ipv6 cef
icense udi pid CISCO1921/K9 sn FGL183123E4
username SJ_Router privilege 15 secret 5 $1$wqbn$w6fdF34HevDaa8OI0gjYm.
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 192.168.100.4 255.255.255.0
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
ip nat inside
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 192.168.100.1
access-list 1 permit 192.168.1.0 0.0.0.255
Can you please help me with this.
2 Accepted Solutions
Aztec_
Hi Mohammed,
i think you need to reconfigure the default-gateway on you DHCP pool.
It supposed to be 192.168.1.1.
then retry pinging to google.
If it still failed, you neeed to verify your ip had been translated.
"#show ip nat translation"
Again, your issue is with your name resolution, something is blocking it
try this in your PC CMD prompt
>nslookup google.com 8.8.8.8
>nslookup google.com 4.2.2.2
that syntax means, look for google.com using DNS server 8.8.8.8 vice versa.
If it displays an error and cannot give you an IP, something in your network or PC itself is blocking name resolution,
also, try using another PC/Laptop.
19 Replies 19
LJ Gabrillo
Level 5
Level 5
Your configuration is okay.
Can you do a traceroute on your PC? let's check where the packets stop
also, an "ipconfig /all" to verify if it got an IP address
do this one
ipconfig /all      -Verify
ping 8.8.8.8      -Ping Public DNS directly
tracert -d 8.8.8.8
Also, i have heard people say that standard ACLs have issues with NAT/PAT in certain ios versions
In my own practice, I always use extended/named extended ACLs
How about you try that
#ip access-list extended NAT
   #permit ip 192.168.1.0 0.0.0.255 any
#ip nat inside source list NAT interface g0/0 overload
STILL, standard ACLs or any type of ACL should work for NAT/PAT. If it is a configuration issue, why not try the above config for isolation :D
I have removed the old standard NAT and configured the new extended one.
but i still face the same situation here, i can ping the 8.8.8.8 i can see system tray that i am connected to internet, my router can ping google.com but my PC can't ping or browse internet.
Hey there, your NAT/PAT configuration is actually working, considering you can ping 8.8.8.8 a public address and NAT translations in your router, you are actually done.
You might have a problem with your DNS, something is blocking DNS name resolution. considering you can ping from your PC to internet, we can see that everything is working fine.
Point is, there is something blocking name resolution. You need to find that, router config side, everything is now fine.
Hi again
now i can ping the IPs of the websites but i cant ping the domain names of the websites.
i.e. i can ping 173.194.66.139, and even if i enter this IP in the browser it directs me to google.com
but i can not ping google.com or try to enter google.com from my browser
Hi Isgabrillo
I tried >nslookup google.com 8.8.8.8 and it didnt give me anything
but when i tried >nslookup google.com 4.2.2.2, it replied back
so i changed the DNS server to 4.2.2.2 and yeah it works just fine.
thank you for the great great support, i would give you a big hug for this.
thanks again for the help
Cool!, Glad i can help, bro hug to you as well
Anyway, I would highly recommend configuring multiple DNS servers, just in case any of those public dns servers fail, such as 8.8.8.8
#ip dhcp pool TEST
  #network 192.168.1.0 255.255.255.0
  #default-router 192.168.1.1
  #dns-server 4.2.2.2 4.2.2.1 8.8.8.8 8.8.4.4     -Maximum of 6
:D
yes i will, i learned a lot from you bro.
thanks for all your great support
I would try to get rid of the double NAT. You could experience problems down the road with other applications. You should be able to bridge your DSL modem so the public IP gets passed down to your router. You may have to call your ISP or you can google your make and model for the password.
Hi avang
thanks for your cooperation, by the way i thought about the same idea, i tried to look for commands that will bridge my interface with modem interface, there is this "IP helper-address" command, but it didnt work right, i tried to make my port transparent but the same result.
if you have a clear idea about something like this, that would be great
the bridge occurs on the DSL modem. What's the make and model of the DSL modem? Most of the time you can web into the DSL modem http://192.168.100.1 or https://192.168.100.1 and make the changes. If you can't you might have to call your local ISP to have them assist you. You will probably need to change your Outside interface Gi0/0 to DHCP after you successfully bridge your DSL modem
ip address dhcp
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 dhcp
Can you run this command and post the output
#show ip virtual-reassembly
Hi Avang
thanks for your reply, the GUI interface doesnt provide anything useful, it only shows some statistics and KPIs, so i talked with the ISP support, they told me that they can't help me with this.
so i think i am gonna have to forget such a thing.
any way i am really thanksful for your cooperation, cheers mate.
BR
