I configure IKEv2 on cisco router to Palo Alto but need to remove pfs from the config
jomo frank
Hello Support,
I configure my cisco 892 router to do ipsec vpn using IKEv2 but the Palo Alto at third party is not using pfs  how can I remove pfs from the configure and just include set group20
crypto map vpn 10 ipsec-isakmp
set peer 1.1.1.1 --> Palo Alto VPN Peer
set transform-set tset
set pfs group20
set ikev2-profile BOG_TEST
match address vpn
2 Accepted Solutions
johnlloyd_13
Level 9
Level 9
hi,
are you referring to keep 'group 20' in the IKEv2 policy/proposal? can you post a 'show run | sec crypto' output.
to remove 'group 20' in the crypto map, just use a 'no' to negate the line.
crypto map vpn 10
 no set pfs group20
make sure you got 'group 20' in any of your IKEv2 proposal. example below:
crypto ikev2 proposal <PROPOSAL NAME>
encryption aes-cbc-128
integrity sha1
group 20
johnlloyd_13
Level 9
Level 9
hi,
make sure both the 892 router and PA FW have identical IKEv2 phase 1 and phase 2 policies to build the IPSec SA.
can you post a 'show run | sec crypto' output to verify?
johnlloyd_13
Level 9
Level 9
hi,
crypto map vpn 10
 no set pfs group20
integrity sha1
group 20
Hello John,
I have group 14 in my IKEv2 proposal.
So your are saying once i this configured in my proposal I could negate the without any problems
I new to IKEv2, hence i am unsure if I could leave the group 14 line in the crypto map
johnlloyd_13
Level 9
Level 9
hi,
