Cisco 2951: %IP: Bad hostname format when using a domain name
roncro
Level 3
Level 3
I own a domain name, let's call it mydomain.us, and I have a few hosts that are multihomed and have a public IP as well as a private IP, and I am trying to see if I can do the following on a Cisco 2951 router.
If I want to use the same hostname/domain name, in the local/private network, and try to enter something like:
Charon-2951(config)#ip host thathost@mydomain.us 192.168.1.113
edit:   oops..  I meant thathost.mydomain.us...
I get:
Is that because the "domain-name localdomain" setting on the router?
(the question actually is, can I get around that?)
thanks,
Ron
balaji.bandi
how about configuring like below example :
ip domain name mydomain.us
ip host thathost 192.168.1.113
BB
5 Replies 5
Richard Burts
Ron
I am not authoritative on this (and if someone who is authoritative would jump in that would be good) but I believe that the issue is that the ip host command expects a simple host name (not associated with a domain name). I do not believe that there is a way around this.
Rick
Hi Rick,
when I revisited the config,  I think I made a typo, that's posibly why I saw the error.
Also,  pretty much all hostnames, for lookups, I have in there are like:
ip host thathost.localdomain 192.168.x.y
It seems the router does accept config lines like:
ip host thathost.mydomain.us 192.168.a.b    while ... if I didn't it would resolve to  thathost.mydomain.us   p.q.r.s, a public address,   which I wanted to prevent.
So what happens is, I think,  that if you tell the router it is 'located' in localdomain, it being   it's domain-name is localdomain,  it treats that as the default domain search.   so if I would like to 'go to'  thathost, my router's domain-name being used as the default search domain, it  assumes I am looking for  thathost.localdomain.  (I think if domain-name was set to   'mydomain.us' it would  assume the hostname i was looking for would be thathost.mydomain.us.)
some of it (above) is what I see, and it looks like that is how it works?
Ron
Ron
I am not clear about your follow up question and am not able to give you an answer for it. Perhaps someone else in the community can help with this.
Rick
balaji.bandi
BB
that is what I started doing,  somehow I was thinking to use two domain names, but that didn't make much sense.
thanks,
Ron
