I do 'no ip nat pool mypool' and get 'cannot destroy' message
news2010a
Level 3
Level 3
I am trying to remove a NAT entry;
I do 'no ip nat pool mypool 195.1.1.1 195.1.1.3 netmask 255.255.255.0'
then the IOS returns:
%Pool globalpool in use, cannot destroy
Can you clarify how I can handle this ? IOS 12.3, C2610.
interface Serial0/0
*Mar 1
ip address 195.1.1.4 255.255.255.0FAILURE: System config parse from (
clockrate 500000
clockrate 500
no fair-queue
no fair
no cdp enable
ftp://255.2
ip nat pool globalpool 195.1.1.1 195.1.1.3 netmask 255.255.255.0
ip nat inside source list 1 pool globalpool
ip http server
no ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/0
access-list 1 permit 10.1.1.2
access-list 1 permit 10.1.1.3
access-list 1 permit 10.1.1.1
access-list 1 permit 10.1.1.4
no cdp run
line con 0
exec-timeout 0 0
line aux 0
line vty 0
8 Replies 8
Edison Ortiz
Marlon,
The reason you are unable to delete the pool is due NAT taking place at the moment.
You need to perform the following commands real quick. If I were you, I copy and paste as a script.
#clear ip nat translation *
#config terminal
(config)#no ip nat pool mypool 195.1.1.1 195.1.1.3 netmask 255.255.255.0
Please rate helpful posts.
There is a document on CCO that describes how to get around precisely this situation:
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094422.shtml
Hope that helps - pls do rate the post if it does
Paresh
foxbatreco
Level 3
Level 3
Hii,
For this to be done properly, clear the translations and then remove the statement.
If still its not happening then remove the internal network physical connection from the router and do it.or you can disable nat on the interfaces,clear the tables and then do it.
Pls rate the post.
This forum is amazing. Thanks.
you can also do it by just issuing command on interface configuration mode "shutdown"
and then you can disable the NAT on the interface...
rate this post if it helps
regards
Devang
elephant1132
under this your cisco command,
just do "no ip nat inside source list 1 pool globalpool" first,
and, "no ip nat pool globalpool 195.1.1.1 195.1.1.3 netmask 255.255.255.0" later.
It is quite, Easy? right?
Ali Alshamrani
try to dislink the pool with the ACL:
no ip nat inside source ( your ACL list ) pool mypool
then distroy your pool
Hello
Clear ip nat translation * force
Kind Regards
Paul
