Multicast Neighbour
feroz syed
Level 3
Level 3
Attached topology, as you can see there are two vrf Red and Blue, the vpnv4 is working file, i have reachability from R1 to R7 via vpvn4,  enabled multicast on R3 and R1 sparse-mode and R5, R7 act as server. R1 joined multicast group address ip igmp join-group 229.1.1.1. i can see the *,G on Router 3 but the neighbor on R5 not showing,
R5#sh ip pim vrf BLUE neighbor
PIM Neighbor Table
Mode: B - Bidir Capable, DR - Designated Router, N - Default DR Priority,
S - State Refresh Capable
Neighbor Interface Uptime/Expires Ver DR
Address Prio/Mode
R5#sh ip pim vrf BLUE inter
Address Interface Ver/ Nbr Query DR DR
Mode Count Intvl Prior
172.57.57.5 FastEthernet2/1 v2/S 0 30 1 172.57.57.5
R5#
R3#sh ip igmp vrf RED membership
Flags: A - aggregate, T - tracked
L - Local, S - static, V - virtual, R - Reported through v3
I - v3lite, U - Urd, M - SSM (S,G) channel
1,2,3 - The version of IGMP the group is in
Channel/Group-Flags:
/ - Filtering entry (Exclude mode (S,G), Include mode (*,G))
Reporter:
<mac-or-ip-address> - last reporter if group is not explicitly tracked
<n>/<m> - <n> reporter in include mode, <m> reporter in exclude
Channel/Group Reporter Uptime Exp. Flags Interface
*,229.1.1.1 172.13.13.1 01:06:09 02:55 2A Fa2/0
*,224.0.1.40 172.13.13.3 01:06:28 02:51 2LA Fa2/0
7 Replies 7
tough one. Can you post the running configs of all participating routers ?
R1 config
R1#sh runn
Building configuration...
Current configuration : 1518 bytes
upgrade fpd auto
version 12.4
hostname R1
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
ip source-route
no ip icmp rate-limit unreachable
ip cef
ip vrf RED
rd 13:13
route-target export 57:57
route-target import 13:13
no ip domain lookup
ip multicast-routing
no ipv6 cef
archive
log config
hidekeys
ip tcp synwait-time 5
interface Loopback0
ip address 1.1.1.1 255.255.255.255
ip ospf 1 area 0
interface FastEthernet0/0
ip address 172.13.13.1 255.255.255.0
ip pim sparse-mode
duplex full
interface FastEthernet1/0
no ip address
shutdown
duplex half
interface FastEthernet2/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet2/1
no ip address
shutdown
duplex auto
speed auto
router ospf 1
log-adjacency-changes
network 192.168.0.0 0.0.255.255 area 0
router rip
version 2
network 1.0.0.0
network 172.13.0.0
no auto-summary
ip forward-protocol nd
no ip http server
no ip http secure-server
no cdp log mismatch duplex
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R1#
R2#sh running-config
Current configuration : 1666 bytes
upgrade fpd auto
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
mpls label range 200 299
archive
log config
hidekeys
interface Loopback0
ip address 2.2.2.2 255.255.255.255
ip pim sparse-dense-mode
ip ospf 1 area 0
interface Loopback1
ip address 22.22.22.22 255.255.255.255
ip pim sparse-mode
ip ospf 1 area 0
ip address 192.168.24.2 255.255.255.0
ip pim sparse-mode
duplex half
ip address 192.168.25.2 255.255.255.0
ip pim sparse-mode
duplex half
ip address 192.168.23.2 255.255.255.0
ip pim sparse-mode
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
router ospf 1
mpls ldp autoconfig
no ip http server
ip pim bsr-candidate Loopback1 0
ip pim rp-candidate Loopback0
mpls ldp router-id Loopback0
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R2#
R3#sh running-config
Current configuration : 2305 bytes
upgrade fpd auto
version 12.4
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
ip vrf RED
rd 13:13
route-target export 13:13
route-target import 57:57
no ip domain lookup
ip multicast-routing vrf RED
no ipv6 cef
mpls label range 300 399
archive
log config
hidekeys
interface Loopback0
ip address 3.3.3.3 255.255.255.255
ip ospf 1 area 0
ip address 192.168.34.3 255.255.255.0
ip pim sparse-mode
duplex half
ip address 192.168.23.3 255.255.255.0
ip pim sparse-mode
duplex half
ip vrf forwarding RED
ip address 172.13.13.3 255.255.255.0
ip pim sparse-mode
duplex auto
speed auto
mpls ip
ip address 192.168.36.3 255.255.255.0
ip pim sparse-mode
duplex auto
speed auto
router ospf 1
mpls ldp autoconfig
router rip
address-family ipv4 vrf RED
redistribute bgp 100 metric 1
network 172.13.0.0
no auto-summary
version 2
exit-address-family
router bgp 100
bgp log-neighbor-changes
neighbor 5.5.5.5 remote-as 100
address-family ipv4
neighbor 5.5.5.5 activate
no auto-summary
no synchronization
exit-address-family
address-family vpnv4
neighbor 5.5.5.5 send-community both
exit-address-family
redistribute rip metric 10
neighbor 5.5.5.5 update-source Loopback0
no synchronization
exit-address-family
no ip http server
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R3#
R4#
R4#
R4#sh runn
R4#sh running-config
Current configuration : 1535 bytes
upgrade fpd auto
version 12.4
hostname R4
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
mpls label range 400 499
mpls label protocol ldp
archive
log config
hidekeys
interface Loopback0
ip address 4.4.4.4 255.255.255.255
ip ospf 1 area 0
ip address 192.168.24.4 255.255.255.0
ip pim sparse-mode
duplex half
ip address 192.168.34.4 255.255.255.0
ip pim sparse-mode
duplex half
ip address 192.168.45.4 255.255.255.0
ip pim sparse-mode
duplex auto
speed auto
ip address 192.168.46.4 255.255.255.0
ip pim sparse-mode
duplex auto
speed auto
router ospf 1
mpls ldp autoconfig
no ip http server
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R5#sh runn
R5#sh running-config
Current configuration : 2379 bytes
upgrade fpd auto
version 12.4
hostname R5
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
ip vrf BLUE
rd 57:57
no ip domain lookup
ip multicast-routing vrf BLUE
no ipv6 cef
mpls label range 500 599
archive
log config
hidekeys
interface Loopback0
ip address 5.5.5.5 255.255.255.255
ip ospf 1 area 0
ip address 192.168.45.5 255.255.255.0
ip pim sparse-mode
duplex half
ip address 192.168.25.5 255.255.255.0
ip pim sparse-mode
duplex half
ip address 192.168.56.5 255.255.255.0
ip pim sparse-mode
duplex auto
speed auto
ip vrf forwarding BLUE
ip address 172.57.57.5 255.255.255.0
ip pim sparse-mode
duplex auto
speed auto
mpls ip
router eigrp 100
no auto-summary
address-family ipv4 vrf BLUE
redistribute bgp 100 metric 100 100 255 1 1
network 172.57.0.0
auto-summary
autonomous-system 100
exit-address-family
router ospf 1
mpls ldp autoconfig
router bgp 100
neighbor 3.3.3.3 remote-as 100
neighbor 3.3.3.3 update-source Loopback0
address-family ipv4
neighbor 3.3.3.3 activate
no auto-summary
no synchronization
exit-address-family
neighbor 3.3.3.3 send-community extended
exit-address-family
redistribute eigrp 100
no synchronization
exit-address-family
no ip http server
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R6#sh running-config
Current configuration : 1501 bytes
upgrade fpd auto
version 12.4
hostname R6
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
mpls label range 600 699
archive
log config
hidekeys
interface Loopback0
ip address 6.6.6.6 255.255.255.255
ip ospf 1 area 0
ip address 192.168.46.6 255.255.255.0
ip pim sparse-mode
duplex half
ip address 192.168.56.6 255.255.255.0
ip pim sparse-mode
duplex half
ip address 192.168.36.6 255.255.255.0
ip pim sparse-mode
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
router ospf 1
mpls ldp autoconfig
no ip http server
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R7#sh running-config
Current configuration : 1386 bytes
upgrade fpd auto
version 12.4
hostname R7
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
archive
log config
hidekeys
interface Loopback0
ip address 7.7.7.7 255.255.255.255
ip ospf 1 area 0
ip address 172.57.57.7 255.255.255.0
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
router eigrp 100
network 7.0.0.0
network 172.57.0.0
no auto-summary
router ospf 1
no ip http server
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
 R7 is server and member of VRF Blue but I see no VRF definition on it.
However the interface on R5, direclty connect does:
ip pim sparse-mode
duplex auto
speed auto
mpls ip
R7 is server, it just respond to multicast traffic (ping) also i cannot configure vrf on Customer router R7
But how can it participate of the VRF domain?  Which means your traffic is actually going through the VRF global anyway?
Hello
Try appending the following using MSDP so you can join the two :PM-SM domain together
all rtrs
ip pim rp-address x.x.x.x ( address of RP)
R3
ip msdp peer 5.5.5.5 connect-as loopback 0
r5
ip msdp peer 3.3.3.3 connect-as loopback 0
Kind Regards
Paul
