I need help configuring a static route
hfakoor222
I cannot get any of my VPC'sto pint router R2
I can get them to ping segments attached to R2
I want to focus on pinging from PC2 (right side) to R2
EIGRP is configured everywhere, I have connections between PCS, but nothing seems to be getting to R3
I am attempting a GLBP project - i have subinterfaces configured on R3 and R2 pointing downstream, the interfaces themselves have no IP, except for the subinterfaceThe lab I'm piggybacking off of seems to be able to get to R2 through having subinterfaces ip addressed only
Baically i want help in configuring a static route to R2 from R3
Interfaces on R3
here is a routing table
on R3
here is the running config of R3
rrent configuration : 1724 bytes
version 12.4
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
archive
log config
hidekeys
ip tcp synwait-time 5
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.10
description Office VLAN 10
encapsulation dot1Q 10
ip address 10.1.10.2 255.255.255.0
glbp 10 ip 10.1.10.254
glbp 10 priority 90
glbp 10 preempt
interface FastEthernet0/0.20
description Server VLAN 20
encapsulation dot1Q 20
ip address 10.1.20.2 255.255.255.0
glbp 20 ip 10.1.20.254
glbp 20 priority 90
glbp 20 preempt
interface FastEthernet0/0.99
encapsulation dot1Q 99
ip address 10.1.99.2 255.255.255.0
shutdown
glbp 99 ip 10.1.99.254
glbp 99 priority 150
glbp 99 preempt
interface Serial0/0
ip address 10.1.2.3 255.255.255.0
clock rate 2000000
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet1/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet2/0
no ip address
shutdown
duplex auto
speed auto
router eigrp 1
redistribute connected
network 10.0.0.0
auto-summary
ip forward-protocol nd
no ip http server
no ip http secure-server
no cdp log mismatch duplex
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
and running config of R2 top router
rsion 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
archive
log config
hidekeys
interface Loopback0
ip address 10.1.202.1 255.255.255.255
no ip address
duplex auto
speed auto
ip address 10.1.10.1 255.255.255.0
glbp 10 priority 150
glbp 10 preempt
glbp 20 priority 150
glbp 20 preempt
glbp 99 preempt
interface Serial0/0
ip address 10.1.1.2 255.255.255.0
clock rate 2000000
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0
no ip address
shutdown
serial restart-delay 0
interface Serial1/1
no ip address
shutdown
interface Serial1/2
ip address 10.1.2.2 255.255.255.0
interface Serial1/3
no ip address
shutdown
no ip address
shutdown
duplex auto
speed auto
router eigrp 1
network 10.0.0.0
auto-summary
ip route 0.0.0.0 0.0.0.0 10.1.2.3
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
I would like suggestions on configuring a static route to move traffic from Pc2 to R2
Everywhere has connectivity except nothing seems to get past either router to get to R2
11 Replies 11
A couple things I noticed.
-Interface g0/0.99 on R3 was shut down - not sure if that was intentional
-EIGRP is configured but auto-summary is on. Since you have discontiguous networks I would turn that off. That can wreak havoc on routing.
For a static route the syntax is: ip route <destination network> <destination mask> <next-hop ip (or) exit interface>
-David
follow
hfakoor222
Ive tried both 0.0.0.0 0.0.0.0 10.1.2.2 on R3
and 0.0.0.0 0.0.0.0 10.1.2.3 on R2 with no success in pinging R2
and I would like any suggestions
I will go ahead and turn off EIGRp auto-summary
So a default route is for saying if you don’t know where to send me go this way. What you configured was 2 default routes pointing to each other which won’t provide full connectivity.
For the full connectivity enter on all routers:
router eigrp 1
network 10.0.0.0 0.255.255.255
no auto-summary
then please post the sho up route and show up protocols for all 3 routers.
-David
I removed static routes and redid the eigrp commands
router eigrp 1
no auto-summary
for   R2
no luck getting to R2 I can still get to the segments on the other side of the GLBP routers
Here's R2's  config
R2#sh running-config
Building configuration...
Current configuration : 1796 bytes
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
archive
log config
hidekeys
interface Loopback0
no ip address
duplex auto
speed auto
glbp 10 preempt
glbp 20 preempt
glbp 99 preempt
interface Serial0/0
clock rate 2000000
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0
no ip address
shutdown
interface Serial1/1
no ip address
shutdown
interface Serial1/2
interface Serial1/3
no ip address
shutdown
no ip address
shutdown
duplex auto
speed auto
router eigrp 1
network 10.0.0.0
no auto-summary
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
I retried a static route
0.0.0.0 0.0.0.0 s0/0
and still no luck
You have used the same subnets on R2 and R3 eg. 10.10.1.0/24 but there is no L2 path between R2 and R3 ie. they are separated by a L3 link using 10.1.2.0/24 so that will not work.
You can't have the same IP subnet separated by another subnet, it won't route properly.
Jon
I changed s1/2 on R3 from 10.1.2.3 to 10.1.3.5 and get a not on same subnet
*Mar 1 00:23:59.935: IP-EIGRP(Default-IP-Routing-Table:1): Neighbor 10.1.3.5 not on common subnet for Serial0/0
and the packet gets lost in transit when pinging
*10.1.10.2 icmp_seq=1 ttl=255 time=228.349 ms (ICMP type:11, code:0, TTL expired in transit)
*10.1.10.2 icmp_seq=2 ttl=255 time=236.962 ms (ICMP type:11, code:0, TTL expired in transit)
*10.1.10.2 icmp_seq=3 ttl=255 time=234.256 ms (ICMP type:11, code:0, TTL expired in transit)
*10.1.10.2 icmp_seq=4 ttl=255 time=245.914 ms (ICMP type:11, code:0, TTL expired in transit)
*10.1.10.2 icmp_seq=5 ttl=255 time=231.994 ms (ICMP type:11, code:0, TTL expired in transit)
You misunderstood what I was saying.
Just realised, is your description in your first post wrong ie. R2 has no fa0/0 interface on it so do you mean R1 ?
Jon
the SW is L2SW ?
If yes then
you need to config HSRP in both Router
you need to assign VIP of HSRP as Default GW in each PC
you need to be sure that the trunk between two SW is allow all VLAN.
The gateway for PC 2 is as follows
IP/MASK : 10.1.10.102/24
GATEWAY : 10.1.10.254
DNS :
MAC : 00:50:79:66:68:00
LPORT : 20062
RHOST:PORT : 127.0.0.1:20063
MTU : 1500
PC2>
I also tried a 10.1.10.1 gateway same results
10.1.10.254 <- this IP for what Router or SVI
