I need help, please
JennisJennis
Okay so I have this troubleshooting task where I have to get all the pc/laptops to ping each other by only making use of RIP. It's been a month since I learned about RIP so i am completely rusty and I don't know what to do. The text is in danish and translates as follows:
Task
In this task, you must find out why one PC cannot ping all other PCs
Only RIP must be used
Get all LAN clients to ping each other
If there is something in the RIP that does not fit, then it must be removed.
Hello
See attached working PT file
RIpv2 with
auto-summarization
disabled and advertising the transit and local subnets
Kind Regards
Paul
check if your all routers configured with RIP and networks related to each router added to RIP. verify all routers using one of RIP version (v1 or v2). check all interfaces in routers and verify passive interface is not configured between routers.
Good luck
KB
Hello
RIpv2 with
auto-summarization
Kind Regards
Paul
