i need simple qos config
anand.narine1
my situation is
clients -------------- routerA------------------10Mbps----------------routerB-----------5Mbps internet
RouterB is connected to the internet 5Mbps dsl modem. I want to guarantee some important clients at least 90% internet bandwidth. Can anyone share the qos commands that will work for this?
17 Replies 17
John Blakley
You can. Create an acl like mentioned above matching on the hosts that you want. Create a class map matching on this acl and your protocols and apply to a policy map.
Access-list 10 permit host 1.1.1.1
Access-list 10 permit host 1.1.1.2
Class-map Internet
Match access-group 10
Match protocol http
Policy-map Internet
Class Internet
Bandwidth percent 90
Shape average 4500000
Class class-default
Fair-queue
It will match only hosts 1.1.1.1 and .2. If .3 wants to go to the internet, they would hit the default class.
HTH, John *** Please rate all useful posts ***
how does the code in this thread code compare to the following?
https://learningnetwork.cisco.com/message/339947#339947
I do beleive it all depends on your requirements. If this is the same scenario as before, I beleive the requirements were as follows:
1. There is a 10meg interface connecting upstream to an ISP that has a CIR of 5mbit.
2. All internet traffic needs to be at 5mbit as this is ISP CIR. CEO on the LAN needs to be able to use up to 90% of this internet bandwidth if he so chooses at any given time.
3. On the same 10meg link, there are connections to other internal servers/services that do not need to be within the 5meg QoS limit.
In order to define a good QoS policy for this, can you give us a diagram with CEO, LAN, 5M WAN, and servers?
