iBGP local preference conflict
tedauction
Hello, I have two adjacent iBGP VRFs, which each have a bordering eBGP VRF (diagram attached).
My topology includes a route for 10.0.0.0/8 which I am passing from each of the eBGP VRFs into the inside iBGP VRFs. I am preferring eBGP VRF route paths over the other by using AS prepending.
The problem is that by default, when the iBGP VRFs receive this 10.0.0.0/8 route, they forward this route to each other with the 'Local Preference' default attribute of 100 (expected iBGP behaviour). This is installed in their routing tables due to 'Local Preference' having a higher order of preference than AS prepending.
Is there any way, I can force the iBGP VRFs to instead recognise the 'AS prepend' attribute rather than the 'Local Preference' attribute - or is it not feasible to try to pass routes via iBGP and eBGP VRFs as per my topology ?
5 Replies 5
There is nothing with LP,
Can i see
Show ip bgp 10.0.0.0?
Cisco Best Path
""Prefer the path with the shortest AS_PATH.""
NOW
AS prepend x3 from Side
AS prepend x2 from other Side (keep notice that iBGP not add AS-path)
so for iBGP vrf-A it better via iBGP than eBGP because it have shortest path.
so I think you make misconfig
instead in eBGP AS 65100 use x2
in eBGP AS 65000 use x3
 "...The problem is that by default, when the iBGP VRFs receive this 10.0.0.0/8 route, they forward this route to each other with the 'Local Preference' default attribute of 100 (expected iBGP behaviour). "
https://networkengineering.stackexchange.com/questions/44908/why-are-ibgp-routes-not-propagated-to-other-ibgp-neighbors
This is wrong.  The expected behavior is not advertise routes leaned from iBGP peer as Loop prevention mechanism.
Harold Ritter
Hi @tedauction ,
The local preference is the same for all eBGP learnt routes (100). It should therefore not play a role in the best path selection.
Please provide the output for "show bgp vrf <vrf name> ipv4 uni 10.0.0.0/8" from both iBGP peers.
Hello
Set the LP attribute higher than current default (100) for those specific routes to take the egress path you wish.
Example:
ip prefix-list LP_pf permit 10.0.0.0/8 ge 32
route-map LP_rm permit 10
match ip address prefix-list LP_pf
set local-preferance 200
route-map LP_rm permit 99
router xxx
neigbour <Ebgp peer> route-map LP_rm IN
Kind Regards
Paul
