IENET WIC card
thiru.vel10
Hi All,
I am having 1Enet WIC card in 1700 cisco router. I would like to install the same card to 2621 router. Could any one tell me if it is possible or not . thanks a lot
Edison Ortiz
Edison Ortiz
I'm afraid not, please see this link for confirmation:
http://www.cisco.com/en/US/products/hw/routers/ps214/products_tech_note09186a00800ae37f.shtml
HTH,
__
Edison.
Thanks for you update I have tried but the 1700 router ENET is not supported to 2621 router. So I installed HEnet Card .
vaisharm
Hi there,
WIC-1ENET is not supported on 2600 series routers.
Included below are some supporting documents:
Overview of Cisco Interface Cards for Cisco Access Routers
http://www.cisco.com/en/US/products/hw/modules/ps2641/products_module_installation_guide_chapter09186a008007cb95.html#wp1129978
HTH, do rate the post if it does.
~Vaibhav
