IGMP - PIM Dense Mode - Joining to Multicast Group 224.0.1.40
David Salazar
Hi everybody
I have a router configure with pim dense mode and when I used some command to verify the operation I can see that the router show joining to multicast group 224.0.1.40. Can anybody tell me why?
RA#sh ip pim interface
Address          Interface                Ver/   Nbr    Query  DR     DR
                                          Mode   Count  Intvl  Prior
100.100.100.1    Loopback0                v2/D   0      30     1      100.100.100.1
10.10.10.1       Serial0/0                v2/D   2      30     1      10.10.10.3
RA#
RA#
RA#sh ip igmp gro
RA#sh ip igmp groups
IGMP Connected Group Membership
Group Address    Interface                Uptime    Expires   Last Reporter   Group Accounted
224.0.1.40       Serial0/0                00:57:40  00:02:57  10.10.10.3
224.0.1.40       Loopback0                00:59:10  00:02:55  100.100.100.1
RA#
RA#
RA#sh ip igm
RA#sh ip igmp interface
Loopback0 is up, line protocol is up
  Internet address is 100.100.100.1/32
  IGMP is enabled on interface
  Current IGMP host version is 2
  Current IGMP router version is 2
  IGMP query interval is 60 seconds
  IGMP querier timeout is 120 seconds
  IGMP max query response time is 10 seconds
  Last member query count is 2
  Last member query response interval is 1000 ms
  Inbound IGMP access group is not set
  IGMP activity: 1 joins, 0 leaves
  Multicast routing is enabled on interface
  Multicast TTL threshold is 0
  Multicast designated router (DR) is 100.100.100.1 (this system)
  IGMP querying router is 100.100.100.1 (this system)
Multicast groups joined by this system (number of users):
      224.0.1.40(1)
Serial0/0 is up, line protocol is up
  Internet address is 10.10.10.1/24
  Multicast designated router (DR) is 10.10.10.3
  IGMP querying router is 10.10.10.1 (this system)
  No multicast groups joined by this system
RA#
The other strange thing is that the show ip pim autorp the output show AutoRP enabled, is posible disable it?
RA#
RA#sh ip pim autorp
AutoRP Information:
  AutoRP is enabled.
PIM AutoRP Statistics: Sent/Received
  RP Announce: 0/0, RP Discovery: 0/0
RA#
RA#
Thank a lot.
DS
Peter Paluch
Hi David,
The 224.0.1.40 group is the Cisco-RP-Discovery group. This is a reserved multicast group in the Auto-RP system that is used to propagate information about existing rendezvous points and group-to-RP mappings. This group always works in the dense mode and that is probably the reason why you see your router being subscribed to it even though you have configured PIM-DM as your multicast routing protocol that does not need RPs.
Regarding the possibility of deactivate Auto-RP, Laurent Aubert answers this question in this thread:
https://supportforums.cisco.com/message/3035054#3035054
In short, you need a recent IOS version to be able to deactivate the Auto-RP, otherwise, it is permanently active.
Best regards,
Peter
Argenisga16
Hi.
You can visit this link http://cciepursuit.wordpress.com/category/multicast/  there you will have the solution.
Bye
