IGP Redistributed routes not redistributed into BGP
Kenneth Goh
R1 fa0/0 and R3 fa0/1 are OSPF neighbors
R1 fa0/1, R2 and R3 fa1/0 are EIGRP neighbors
R3 fa0/0 and R4 are iBGP neighbors
Redistribution only happens between:
  1. OSPF and EIGRP on R1
  2. EIGRP and BGP on R3
    Without redistribution between OSPF and BGP, is there a way for R4 is learn 192.168.13.0/24 routes and R1 to learn 10.1.1.0/24 routes
R1#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
C 192.168.12.0/24 is directly connected, FastEthernet0/1
C 192.168.13.0/24 is directly connected, FastEthernet0/0
D 192.168.23.0/24 [90/30720] via 192.168.12.2, 00:33:41, FastEthernet0/1
D EX 192.168.34.0/24 [170/2565376] via 192.168.12.2, 00:09:54, FastEthernet0/1
R4#sh ip route
B 192.168.12.0/24 [200/30720] via 192.168.23.2, 00:23:41
4.0.0.0/32 is subnetted, 1 subnets
C 4.4.4.4 is directly connected, Loopback0
10.0.0.0/24 is subnetted, 1 subnets
C 10.1.1.0 is directly connected, FastEthernet0/1
B 192.168.23.0/24 [200/0] via 192.168.34.3, 00:23:46
C 192.168.34.0/24 is directly connected, FastEthernet0/0
Redistribution on R1
router eigrp 100
redistribute ospf 1 metric 100000 1 255 1 1500
network 192.168.12.0
no auto-summary
router ospf 1
log-adjacency-changes
redistribute eigrp 100 subnets
Redistribution on R3
router eigrp 100
redistribute bgp 64512 metric 100000 1 255 1 1500
network 192.168.23.0
no auto-summary
router ospf 1
router bgp 64512
no synchronization
bgp log-neighbor-changes
network 192.168.34.0
neighbor 192.168.34.4 remote-as 64512
no auto-summary
32 Replies 32
Infinite fd of .13.0
So same issue eigrp see that connect is better than so it never redistribute.
I hope get the issue here, the issue from the each routing protocol have it algorithm to prevent routing loop and prevent the suboptimal path.
Good Luck Friend.
I managed to get end to end reachability by advertising a default route to R4 and network 192.168.34.0/24.
Any reason for your suggestion not to advertise 192.168.34.0/24?
Updated config below
hostname R1
interface FastEthernet0/0
ip address 192.168.13.1 255.255.255.0
ip ospf network point-to-point
ip ospf 1 area 0
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.12.1 255.255.255.0
duplex auto
speed auto
router eigrp 100
redistribute ospf 1 metric 1000 1 255 1 1500 route-map EIGRP-TO-OSPF
no auto-summary
router ospf 1
redistribute eigrp 100 subnets route-map EIGRP-TO-OSPF
ip prefix-list TAG-10 seq 5 permit 10.1.1.0/24
route-map EIGRP-TO-OSPF deny 10
match ip address prefix-list TAG-10
route-map EIGRP-TO-OSPF permit 20
hostname R3
interface GigabitEthernet1
ip address 192.168.13.3 255.255.255.0
ip ospf 1 area 0
negotiation auto
no mop enabled
no mop sysid
interface GigabitEthernet2
ip address 192.168.23.3 255.255.255.0
negotiation auto
no mop enabled
no mop sysid
interface GigabitEthernet3
ip address 192.168.34.3 255.255.255.0
negotiation auto
no mop enabled
no mop sysid
router eigrp 100
redistribute bgp 64512 metric 1000 1 255 1 1500
router ospf 1
router bgp 64512
bgp redistribute-internal
bgp suppress-inactive
redistribute static
neighbor 192.168.34.4 next-hop-self
default-information originate
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip route 0.0.0.0 0.0.0.0 Null0
hostname R4
ip address 192.168.34.4 255.255.255.0
negotiation auto
no mop enabled
no mop sysid
ip address 10.1.1.4 255.255.255.0
negotiation auto
no mop enabled
no mop sysid
router bgp 64512
network 10.1.1.0 mask 255.255.255.0
neighbor 192.168.34.3 remote-as 64512
R4#show ip bgp | b Network
Network Next Hop Metric LocPrf Weight Path
*>i 0.0.0.0 192.168.34.3 0 100 0 ?
*> 10.1.1.0/24 0.0.0.0 0 32768 i
*>i 192.168.12.0 192.168.34.3 28416 100 0 ?
*>i 192.168.23.0 192.168.34.3 0 100 0 ?
r>i 192.168.34.0 192.168.34.3 0 100 0 i
