IGP Redistributed routes not redistributed into BGP
Kenneth Goh
R1 fa0/0 and R3 fa0/1 are OSPF neighbors
R1 fa0/1, R2 and R3 fa1/0 are EIGRP neighbors
R3 fa0/0 and R4 are iBGP neighbors
Redistribution only happens between:
  1. OSPF and EIGRP on R1
  2. EIGRP and BGP on R3
    Without redistribution between OSPF and BGP, is there a way for R4 is learn 192.168.13.0/24 routes and R1 to learn 10.1.1.0/24 routes
R1#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
C 192.168.12.0/24 is directly connected, FastEthernet0/1
C 192.168.13.0/24 is directly connected, FastEthernet0/0
D 192.168.23.0/24 [90/30720] via 192.168.12.2, 00:33:41, FastEthernet0/1
D EX 192.168.34.0/24 [170/2565376] via 192.168.12.2, 00:09:54, FastEthernet0/1
R4#sh ip route
B 192.168.12.0/24 [200/30720] via 192.168.23.2, 00:23:41
4.0.0.0/32 is subnetted, 1 subnets
C 4.4.4.4 is directly connected, Loopback0
10.0.0.0/24 is subnetted, 1 subnets
C 10.1.1.0 is directly connected, FastEthernet0/1
B 192.168.23.0/24 [200/0] via 192.168.34.3, 00:23:46
C 192.168.34.0/24 is directly connected, FastEthernet0/0
Redistribution on R1
router eigrp 100
redistribute ospf 1 metric 100000 1 255 1 1500
network 192.168.12.0
no auto-summary
router ospf 1
log-adjacency-changes
redistribute eigrp 100 subnets
Redistribution on R3
router eigrp 100
redistribute bgp 64512 metric 100000 1 255 1 1500
network 192.168.23.0
no auto-summary
router ospf 1
router bgp 64512
no synchronization
bgp log-neighbor-changes
network 192.168.34.0
neighbor 192.168.34.4 remote-as 64512
no auto-summary
32 Replies 32
balaji.bandi
If the Default Route towards R3, and R3 is aware of that route, it should work for the reachability,
until your goal like to see the routes in the routing table, then you need to redistribute.
BB
There is no default route towards R3, I am not sure why R1 and R4 are not seeing the routes since there's redistribution between OSPF and EIGRP on R1 and EIGRP and BGP on R3.
post the output of 'show ip route' from R2 and R3. In theory, if you mutually redistribute OSPF and EIGRP on R1, and BGP and EIGRP on R3, R4 should see all routes, so redistribution should not be necessary.
Better yet, post the full running configs of all 4 routers.
R1, R2, R3 & R4 show ip route below
R1#show ip route
D 192.168.23.0/24 [90/30720] via 192.168.12.2, 00:17:36, FastEthernet0/1
D EX 192.168.34.0/24 [170/30976] via 192.168.12.2, 00:17:36, FastEthernet0/1
R2#show ip route
D EX 192.168.13.0/24 [170/28416] via 192.168.12.1, 00:04:32, FastEthernet0/1
C 192.168.23.0/24 is directly connected, FastEthernet0/0
D EX 192.168.34.0/24 [170/28416] via 192.168.23.3, 00:04:32, FastEthernet0/0
R3#sh ip route
D 192.168.12.0/24 [90/30720] via 192.168.23.2, 00:03:13, FastEthernet1/0
C 192.168.13.0/24 is directly connected, FastEthernet0/1
B 10.1.1.0 [200/0] via 192.168.34.4, 00:02:09
C 192.168.23.0/24 is directly connected, FastEthernet1/0
R4#sh ip route
B 192.168.12.0/24 [200/30720] via 192.168.23.2, 00:12:18
B 192.168.23.0/24 [200/0] via 192.168.34.3, 00:12:23
R1, R2, R3 & R4 show run below
R1#sh run
Building configuration...
Current configuration : 1246 bytes
upgrade fpd auto
version 12.4
hostname R1
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
ip source-route
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
no ipv6 cef
archive
log config
hidekeys
ip tcp synwait-time 5
interface FastEthernet0/0
ip address 192.168.13.1 255.255.255.0
ip ospf 1 area 0
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.12.1 255.255.255.0
ip ospf network point-to-point
duplex auto
speed auto
router eigrp 100
no auto-summary
router ospf 1
ip forward-protocol nd
no ip http server
no ip http secure-server
no cdp log mismatch duplex
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R2#show run
Current configuration : 1099 bytes
upgrade fpd auto
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
archive
log config
hidekeys
ip address 192.168.23.2 255.255.255.0
duplex auto
speed auto
ip address 192.168.12.2 255.255.255.0
duplex auto
speed auto
router eigrp 100
no auto-summary
no ip http server
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R3#show run
Current configuration : 1464 bytes
upgrade fpd auto
version 12.4
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
archive
log config
hidekeys
ip address 192.168.34.3 255.255.255.0
duplex auto
speed auto
ip address 192.168.13.3 255.255.255.0
ip ospf 1 area 0
duplex auto
speed auto
interface FastEthernet1/0
ip address 192.168.23.3 255.255.255.0
duplex half
router eigrp 100
no auto-summary
router ospf 1
router bgp 64512
no synchronization
no auto-summary
no ip http server
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R4#show run
Current configuration : 1195 bytes
upgrade fpd auto
version 12.4
hostname R4
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
archive
log config
hidekeys
ip address 192.168.34.4 255.255.255.0
duplex auto
speed auto
ip address 10.1.1.4 255.255.255.0
duplex auto
speed auto
router bgp 64512
no synchronization
network 10.1.1.0 mask 255.255.255.0
neighbor 192.168.34.3 remote-as 64512
no auto-summary
no ip http server
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
Jon Marshall
For R1 to learn 10.1.1.0/24 you need to advertise in BGP so it can be redistributed into EIGRP ie. -
router bgp 64512
Not clear on the other one without seeing routing tables from all routers.
Jon
10.1.1.0/24  was advertised on R4, and below are the show ip route for R1 and R2
R4#sh run | sec router bgp
router bgp 64512
no synchronization
no auto-summary
R1#sh ip route
D 192.168.23.0/24 [90/30720] via 192.168.12.2, 00:04:39, FastEthernet0/1
D EX 192.168.34.0/24 [170/30976] via 192.168.12.2, 00:04:39, FastEthernet0/1
R2#show ip route
the below should work (without redistributing between OSPF and BGP on R3):
R1
router ospf 1
network 192.168.13.0 0.0.0.255 area 0
router eigrp 100
default-metric 1000 33 255 1 1500
redistribute ospf 1
R2
router eigrp 100
R3
router eigrp 100
router ospf 1
router bgp 64512
bgp redistribute-internal
R4
router bgp 64512
The config I shared with you were identical in redistribution, but as you can see the show ip route on R1 & R2 are not showing the 10.1.1.0/24 network and R4 is not seeing 192.168.13.0/24.
the configs are not identical. R3 needs the line marked in bold:
router bgp 64512
Now both R1 and R2 could see 10.1.1.0/24. But R4 is still not seeing 192.168.13.0/24.
R1#show run | s router
router eigrp 100
redistribute ospf 1
no auto-summary
router ospf 1
R1#show ip ospf interface brief
Interface PID Area IP Address/Mask Cost State Nbrs F/C
Fa0/0 1 0 192.168.13.1/24 1 DROTH 1/1
R4#sh ip route
B 192.168.12.0/24 [200/30720] via 192.168.23.2, 00:59:55
B 192.168.23.0/24 [200/0] via 192.168.34.3, 01:00:00
check the configs I sent earlier. Make sure R1 looks exactly like this:
router ospf 1
router eigrp 100
redistribute ospf 1
I think the issue is on R3 not redistributing from EIGRP into BGP as route 192.168.13.0 is seen on R2 so it is learning from R1.
R2#sh ip route | in 192.168.13.0
D EX 192.168.13.0/24 [170/2562816] via 192.168.12.1, 00:10:28, FastEthernet0/1
R3
router bgp 64512
no synchronization
no auto-summary
R3#sh ip route
D 192.168.12.0/24 [90/30720] via 192.168.23.2, 01:24:28, FastEthernet1/0
O E2 10.1.1.0 [110/20] via 192.168.13.1, 00:00:02, FastEthernet0/1
R4#sh ip route 192.168.13.0
% Network not in table
what does the OSPF configuration on R3 look like ? Make sure it is:
router ospf 1
