Increasing input errors and CRCs
bapatsubodh
This situation is very surprising !
On our 2 mbps point to point link we get perfect ping from one router to another router serial address also a perfect ping from Pc's from either side of link. With no input error's and no CRCS. But when we start our web application suddenly there is increase in input errors and CRCs due to this ( Probably) some web pages are not seen properly. When we directed this traffic via other Link using route-maps application works ok. Is there any relation betwwen applicatin data and input errors and CRC's ? Is there any way to detect that the errors are due to occourance of what event.
Thanks in advance
Subodh
5 Replies 5
spremkumar
Level 9
Level 9
Better to check out the physical link for reliability and errors.
You can do the same by asking physical loop from the local telco on both the sides and check for the reliability and errors..
once you are done with the loop test you can move onto troubleshooting next probability of errors..
regds
akhan2004
Look, have you checked your webserver, might be some tcp/udp ports are vulnerable, due to this reason whenever you switch on your web server, it generates CRC counts, as soon you disconnect, its OK, either problem in your webserver cable or port level.
kamal-learn
Level 4
Level 4
hi
in addition to what have been posted or in more detail check for any speed or duplex mismatch in that interface,check for the MTU also.
thanx
Could you post a show int for the interface running errors as well as a ping?
When the crc's /errors occur does the link run full?
Does the 2MB run btn you and ISP or you and remote client/ Office? What does the other side look like?
If you clear counters on the interfaces on both sides and check? Do a ping from the other side back and check interface on other side?
It could be a physical layer problem but its best to check this as well.
akhan2004
Make troubleshooting steps:
You said 2MB P2P link - fine,
router to router serial address - fine
PC from either side of line = fine
Have you check your notebook on the same cable instead of webserver? = whats the result?
It seems that outside traffic generated CRC due to some open tcp/udp ports in your Webserver.
http://cisco.com/en/US/products/sw/iosswrel/ps1831/products_tech_note09186a00800a6057.shtml.
Could you pls make it design and attach to your msg, it will give us more clear picture.
