Install mode ISR1K 16.9 - remote upgrade
pmorvay
Hi I decided to upgrade my ISR 1100 to latest 16.9.3. Please help how to enable install/packages mode
I followed the guide, but there is a ridiculous step which shows to boot to rommon and select packages
I did
request platform software package expand file bootflash:isr1K.bin to bootflash:mydir
but the next steps show reload to rommon and boot the packages.
rommon 1 > boot bootflash:mydir/packages.conf
https://www.cisco.com/c/en/us/td/docs/routers/access/1100/software/configuration/xe-16-9/cisco_1100_series_swcfg_xe_16_9_x/cisco_1100_series_swcfg_chapter_0111.html
Is there a way how to upgrade remotely the ISR1K to install mode?
Something like in past with 3850 "software install" - this command expanded the file and also set correct path to packages.conf
Thank you
Leo Laohoo
When it comes to switches, Install Mode is better.
But when talking about routers, I just use Bundle Mode.
