Routing a single device
jasongr33nway
I need to test ipsec config at DR site. Our L3 device uses BGP. I need to take one device and force it's traffic to our DR and not use the BGP route. Can anyone help me with this config?
12 Replies 12
balaji.bandi
You need to show your toplogy and some configuration, with the information you have provided not going enough for us to think what is exiting setup and arrangements.
BB
We have devices that need data routed out of our firewall and over an IPsec tunnel to a vendor. I am in the process of configuring our DR to be able to route this traffic to our vendor if our main site goes down. Right now our L3 device has BGP routes that point to our firewall as a next hop for this traffic. I need to take one of the devices that typically uses the BGP routes to instead route out of our MPLS interface and to our DR site in order to test that the IPsec tunnel is configured properly.
Current Topology: Packet -----> L3 Device ----> Firewall ------> IPsec Tunnel
Testing Topology: Packet -----> L3 Device ----> MPLS ------> DR L3 Device------> DR Firewall ----->IPsec Tunnel
Jaderson Pessoa
You can use
network backdoor
See http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00800c95bb.shtml#bgpbackdoor
for an example.
Jaderson Pessoa
*** Rate All Helpful Responses ***
Hello
I would say BGP backdoor feature is a good feature and suggestion  however it would only be really applicable if there is an igp running between the alternative path which at this time the OP doesn’t state  and then if you have hundreds of routes or subnets to advertise it could be a really quite administrative- other possible options may in include PBR or conditional route advertisement.
Kind Regards
Paul
Thanks everyone for all of your help.
I don't believe BGP Backdoor would help me, unless I am not understanding something in the BGP Case Study link.
I have multiple devices that need to send traffic over the IPsec tunnel on our local firewall which they are doing now and with no issues. I am trying to test the DR firewall config without changing the route path for all of our devices and possibly interrupting normal business operations. That's why I was hoping I could take one of those devices and route it's traffic towards DR while the rest of the devices continue to route traffic as they normally would out of our local firewall.
Hello
Sounds like PBR would be the answer, post a topology diagram so we can review it - and if applicable configuration your router
Kind Regards
Paul
Yes, now we have a clear vision about your doubt. You will need a PBR to control this traffic between these devices.
check link below to more information.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/15-0SY/configuration/guide/15_0_sy_swcg/policy_based_routing_pbr.pdf
Jaderson Pessoa
@Jaderson Pessoa
Really?
@jasongr33nway  If you have posted the topology/configuration already - then apologies i may have missed it -
FYI -without knowing your current setup it would be hard to suggest the correct resolution PBR or otherwise
Kind Regards
Paul
Thanks for it. You has right :)
Because he input it:
Jaderson Pessoa
jasongr33nway
Thanks for al of your help guys!
PBR worked just as I needed it to.
Thanks for the update confirming that PBR did work and was the solution for your requirement.
Rick
Rick
Great mark as solved and helpful all post that were help you
Jaderson Pessoa
