install one card pa-4t+ in one router 7206VXR
griffith2009
I need to install one card pa-4t+ in one router 7206VXR (NPE400).
Does this router is hot-swap?, Can I do the installation of the card without problems?
The router have 128 MByte de ram, That is enough?
Cards:
2 FastEthernet/IEEE 802.3 interface(s)
8 Serial network interface(s)
2 Channelized E1/PRI port(s)
1 Voice resource(s)
paolo bevilacqua
Yes, hot-swap and you should not have any problem.
Leo Laohoo
What's current the bandwidth points of each side before the installation?
He mentioned the cards above. All low/medium speed, not to worry about.
