取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
9
回复
installed VWIC3-2MFT-T1/E1 into 1921, no serial interfaces
mpkohan
Ok I need some help on this one.
I have spent about 6 hours scouring the internet but nothing even comes close to helping.
I have installed a VWIC3-2MFT-T1/E1 into a 1921 as you can see from these outputs from 'Show diag' and 'sho inv':
WIC Slot 0:
        VWIC3-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1
        Hardware Revision        : 1.0
        Top Assy. Part Number    : 800-34658-01
        Part Number              : 73-13420-01
        Board Revision           : B0
        Deviation Number         : 0
        Fab Version              : 05
        PCB Serial Number        : FOC19038ER3
        Version Identifier       : V01
        Product (FRU) Number     : VWIC3-2MFT-T1/E1
        CLEI Code                : COUIA7NCAA
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        EEPROM format version 4
        EEPROM contents (hex):
NAME: "VWIC3-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 0", DESCR: "VWIC3-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC3-2MFT-T1/E1  , VID: V01 , SN: FOC19038ER3
I also added the following:
card type t1 0 0
controller T1 0/0/0
 cablelength long 0db
And I am expecting to see Serial interfaces now in the output of 'sho ip int brie' but here is what I am seeing:
Interface                                    IP-Address      OK? Method Status                Protocol
Embedded-Service-Engine0/0 unassigned      YES NVRAM  administratively down down
GigabitEthernet0/0                  10.10.10.10     YES NVRAM  administratively down down
GigabitEthernet0/1                  unassigned      YES NVRAM  administratively down down
Loopback0                              10.27.249.164   YES NVRAM  up                    up
Loopback1                              unassigned      YES unset  up                    up
NVI0                                       10.27.249.164   YES unset  up                    up
Oh the IOS is Version 15.4(3)M
9 条回复9
Can u paste the complete output of "sh ver"
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.4(3)M, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Mon 21-Jul-14 17:38 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
BSD6454 uptime is 21 hours, 54 minutes
System returned to ROM by reload at 19:40:58 UTC Thu May 14 2015
System image file is "usbflash0:c1900-universalk9-mz.SPA.154-3.M.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO1921/K9 (revision 1.0) with 487424K/36864K bytes of memory.
Processor board ID FTX184682KJ
2 Gigabit Ethernet interfaces
1 Serial interface
1 terminal line
2 Channelized T1/PRI ports
DRAM configuration is 64 bits wide with parity disabled.
255K bytes of non-volatile configuration memory.
249840K bytes of USB Flash usbflash0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*1        CISCO1921/K9          FTX184682KJ
Technology Package License Information for Module:'c1900'
Technology    Technology-package                  Technology-package
              Current              Type           Next reboot
ipbase        ipbasek9             Permanent      ipbasek9
security      None                 None           None
data          None                 None           None
NtwkEss       None                 None           None
johnlloyd_13
Level 9
Level 9
hi,
could you add these lines?
network-clock-participate wic 0
network-clock-select 1 T1 0/0/0
isdn switch-type <TYPE>    <<< DEPENDS WITH SP/VENDOR (USUALLY primary-net5)
#isdn switch-type ?
  primary-4ess    Lucent 4ESS switch type for the U.S.
  primary-5ess    Lucent 5ESS switch type for the U.S.
  primary-dms100  Northern Telecom DMS-100 switch type for the U.S.
  primary-dpnss   DPNSS switch type for Europe
  primary-net5    NET5 switch type for UK, Europe, Asia and Australia
  primary-ni      National ISDN Switch type for the U.S.
  primary-ntt     NTT switch type for Japan
  primary-qsig    QSIG switch type
  primary-ts014   TS014 switch type for Australia (obsolete)
Under the command controller t1 add this line
channel-group 1 timeslots 1-24
Rick
Rick
nice rick! forgot that one :)
mpkohan
This is my final goal:
interface Serial0/0/0
 description ATT MPLS T1
 bandwidth 3072
 no ip address
 encapsulation frame-relay
 no fair-queue
 service-module t1 timeslots 1-48
 service-module t1 fdl both
 frame-relay lmi-type cisco
interface Serial0/0/0.777 point-to-point
 description ATT MPLS T1 ePVC to Fidelity IFS ATT MPLS Cloud
 bandwidth 3072
 ip address 10.10.10.10 255.255.255.252
 no ip proxy-arp
 ip accounting output-packets
 ip flow ingress
 ip nat outside
 frame-relay interface-dlci 777 IETF
I do not understand what you are telling us in your most recent post which describes your final goal. Are you telling us that it is now working? Or are you telling us that for some reason  it is still not working?
Have you added the channel-group timeslot command that I suggested? That is the step at which the serial interfaces actually get created.
I believe that the card that you are using for serial interfaces will require configuration a bit different from what you describe as your final goal. In particular I believe that it will not use the service-module commands and the serial interface identification will be slightly different.
Rick
Rick
The above added final goal is what I am trying to accomplish.
I made the change channel-group 1 timeslots 1-24.
After this I see the Serial interface as S0/0/0:1.
Can I add the subinterface s0/0/0.777 now?
Yes. When you configure the channel-group is when you actually get the serial interfaces created. Now you should have no problem in configuring the subinterfaces under the serial interfaces that were created.
Note that the serial interface identifier might be a bit different from s0/0/0.777.
If you are not sure, or if you try it and it does not work, then post the output of show ip interface brief. That should clarify the serial interface identifier to which you add the subinterface.
Rick
Rick
