Multicast traffic to non-multicast devices
kpsudhakar31
Is there any way I can make non-multicast supporting(They cant send IGMP Joins) devices to receive multicast traffic?
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Yes, sometimes there is an interface command that will pull multicast (i.e. it acts like there's a host desiring that multicast stream on that interface).  (I'm sure you would like to know the command, but I forget what it is - someone else will likely post it.)
Also, though, you may need to disable IGMP snooping, if supported, on host's switch, otherwise a IGMP snooping switch will block the multicast to the port.
Thanks for the reply Joseph. I have explained scenario in the below link probably in a better way,
https://supportforums.cisco.com/discussion/12508756/problem-multicast-receivers
Can you kindly look at it once. Apologies for taking you to another thread  :-)..
Appreciate your advice!
