Insufficient HDLC resource for pri-group - it has been removed
rmv72
C1760
I tryed to configure E1 controller -
GW(config)#controller E1 0/0
GW(config-controller)#pri-group timeslots 1-12
%Controller tdm clock does not have voice capability
.%Voice is not enabled on this PRI group
%Insufficient HDLC resource for pri-group - it has been removed
Part of my config:
interface Serial1/0
ip address A.B.C.D 255.255.255.252
encapsulation frame-relay IETF
frame-relay interface-dlci 100
crypto map VPN
interface Serial1/1
no ip address
shutdown
How to resolve it?
m.lammerse
It looks like you're connecting a ISDN pri *voice* interface to an ISDN pri *data* circuit. They are not compatible.
If you need a data connection, you'll have to change the wic or vwic.
If you need a voice connection, you'll have to change the pri circuit.
Problem was here-
tdm clock E1 0/0 data export line
now-both
