Inter VLAN Issue
mmarie
Hello
We have new branch and we will connect it through 4G routers "WAN connection" and L3 switches as below Fig.
From 1-Branch Switch i can ping the 2-Branch Switch, but from (PC-1) i cannot ping (2-Branch Switch) also (PC-2).
Maybe i have missed something.
Here is the Routers and Switches conf.
1-Router
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
S* 0.0.0.0/0 is directly connected, Tunnel1
10.0.0.0/8 is variably subnetted, 5 subnets, 3 masks
C 10.65.17.0/29 is directly connected, Vlan1
L 10.65.17.2/32 is directly connected, Vlan1
C 10.201.51.0/24 is directly connected, Cellular0
L 10.201.51.1/32 is directly connected, Cellular0
S 10.201.56.24/32 is directly connected, Cellular0
172.20.0.0/16 is variably subnetted, 2 subnets, 2 masks
C 172.20.218.196/30 is directly connected, Tunnel1
L 172.20.218.198/32 is directly connected, Tunnel1
2-Router
C 10.66.17.0/29 is directly connected, Vlan1
L 10.66.17.2/32 is directly connected, Vlan1
L 10.201.51.2/32 is directly connected, Cellular0
C 172.20.218.200/30 is directly connected, Tunnel1
L 172.20.218.202/32 is directly connected, Tunnel1
1-Branch Switch
#ip routing
#interface FastEthernet0/1
no switchport
ip address 10.65.17.1 255.255.255.248
#interface FastEthernet0/3
switchport access vlan 10
switchport mode access
interface Vlan10
ip address 10.20.11.254 255.255.254.0
ip default-gateway 10.65.17.2
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1
2-Branch Switch
#ip routing
switchport access vlan 11
#interface FastEthernet0/24
no switchport
ip address 10.66.17.1 255.255.255.248
#interface Vlan11
ip address 10.30.11.1 255.255.255.0
ip default-gateway 10.66.17.2
ip classless
ip route 0.0.0.0 0.0.0.0 10.66.17.2
your help will be highly appreciated
balaji.bandi
Some how the configs not able to download to look.
make sure you have routing in place to reach, post the traceroute where it dropping ?
BB
luis_cordova
Hi @mmarie ,
The routers do not have a route to the VLAN networks (Router 1 to VLAN 26 and Router 2 to VLAN 11).
You can achieve this by configuring a static route or a routing protocol.
Hello
1-Branch Switch
no ip default-gateway 10.65.17.2
no interface Vlan10
interface Vlan26
ip address 10.20.26.254 255.255.254.0
exit
Description PC1 host port
switchport access vlan 26
exit
vlan 26
exit
2-Branch Switch
no ip default-gateway 10.66.17.2
Description PC2 host port
exit
vlan 11
exit
Kind Regards
Paul
