Inter Vlan routing problem
Attila123
Hello Everyone,
I have an IT testlab with a Cisco 880 VA router. It has 4 switchports (FA0-3). I use these switchports only, as for some reason I can't configure the atm/eth0 port.
Configuration: I have got two Vlans: Vlan1 and Vlan2. FA/1, FA/2, FA/3 are parts of Vlan1 a local LAN. Vlan1 has got a permanent IP address, configured by a dhcp server.
FA/0 is part of Vlan2 and Vlan2 has got a static IP address.
I configured static route from Vlan1 network using Vlan2 ip address as exit interface and also a static route from Vlan2 network using Vlan1 ip address as exit interface. But it doesn't work and I don't understand why. I read through L3 switching and router on the stick, but they don't seem to apply for this scenario.
Can someone help me please?
Thank you,
Attila
Show Run Full
version 15.7
no service pad
service password-encryption
no aaa new-model
memory-size iomem 10
ip cef
no ipv6 cef
license udi pid CISCO887VA-M-K9 sn FCZ164690P4
controller VDSL 0
interface Ethernet0
no ip address
shutdown
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface FastEthernet0
switchport access vlan 2
switchport mode access
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
ip address dhcp
interface Vlan2
ip address 192.168.20.2 255.255.255.0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 192.168.10.0 255.255.255.0 Vlan2
ip route 192.168.10.0 255.255.255.0 192.168.20.1
ip route 192.168.20.0 255.255.255.0 Vlan1
ipv6 ioam timestamp
control-plane
vstack
 Show IP route
Gateway of last resort is not set
192.168.10.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.10.0/24 is directly connected, Vlan1
L 192.168.10.3/32 is directly connected, Vlan1
192.168.20.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.20.0/24 is directly connected, Vlan2
L 192.168.20.2/32 is directly connected, Vlan2
Show int Vlan1
Vlan1 is up, line protocol is up
Hardware is EtherSVI, address is e4d3.f168.b328 (bia e4d3.f168.b328)
Internet address is 192.168.10.3/24
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Keepalive not supported
Last input 00:50:24, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
1100 packets input, 91268 bytes, 0 no buffer
Received 896 broadcasts (0 IP multicasts)
124 packets output, 26828 bytes, 0 underruns
0 output errors, 1 interface resets
135 unknown protocol drops
Show int Vlan2
Vlan2 is up, line protocol is up
Internet address is 192.168.20.2/24
Last input 01:14:17, output never, output hang never
597 packets input, 85153 bytes, 0 no buffer
Received 426 broadcasts (10 IP multicasts)
32 packets output, 3174 bytes, 0 underruns
11 unknown protocol drops
15 Replies 15
try the configuration below (important parts marked in bold) where the router itself is the DHCP server:
version 15.7
no service pad
no aaa new-model
ip cef
no ipv6 cef
ip dhcp excluded-address 192.168.10.1
ip dhcp excluded-address 192.168.20.1
ip dhcp pool VLAN1
network 192.168.10.1 255.255.255.0
default-router 192.168.10.1
dns-server 8.8.8.8 8.8.4.4
ip dhcp pool VLAN2
network 192.168.20.1 255.255.255.0
default-router 192.168.20.1
controller VDSL 0
interface Ethernet0
no ip address
shutdown
interface ATM0
no ip address
shutdown
no ip address
no ip address
no ip address
no ip address
interface Vlan1
ip address 192.168.10.1 255.255.255.0
interface Vlan2
ip address 192.168.20.1 255.255.255.0
no ip http server
ipv6 ioam timestamp
control-plane
vstack
