Interface MTU & RX/TX values are high.
Ninad Thakare
I found the following output from my interface showing high MTU values & RX/TX values causing high latency :
Tunnel1190 is up, line protocol is up
  Hardware is Tunnel
  Description: "ABC"
  Internet address is 1.1.1.1/29
  MTU 17886 bytes, BW 100 Kbit/sec, DLY 50000 usec,
     reliability 255/255, txload 255/255, rxload 255/255
  Encapsulation TUNNEL, loopback not set
  Keepalive not set
  Tunnel source 1.1.1.1, destination 2.2.2.2
  Tunnel protocol/transport IPSEC/IP
  Tunnel TTL 255
  Tunnel transport MTU 1446 bytes
  Tunnel transmit bandwidth 8000 (kbps)
  Tunnel receive bandwidth 8000 (kbps)
  Tunnel protection via IPSec (profile "ipsec-profile-vti")
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 6w3d
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 152776
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
  5 minute input rate 204000 bits/sec, 33 packets/sec
  5 minute output rate 272000 bits/sec, 121 packets/sec
     176521998 packets input, 3198683225 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     162077114 packets output, 3749387952 bytes, 0 underruns
     0 unknown protocol drops
Please help me to resolve this.
Ninad Thakare
aftabsiddiqui
txload 255/255, rxload 255/255 --> shows 100% utilized link. The value is calculated txload and rxload express the fraction of used bandwidth (as configured by the bandwidth command on the interface) by the traffic flowing in either direction.
Can you share the running config of the interface?
