Interface not accepting DHCP address
Adam_S
Have configured an interface on cisco 2811 for DHCP, it is up/up but not accepting an address. I've attached a basic config and DHCP debug. Any advice would be appreciated, any further info can be provided.
33 Replies 33
Thanks for that. I will try changing the config register and the rest of
the config is only 1/2 built at present. I removed the
ip nat
outside just
for testing purposes. I will let everyone know how it goes.
Hello Adam,
Perfect.
One more thing: When you change the config register and reload, then after the router boots up again, it will still read the
ip broadcast-address 0.0.0.0
commands from its startup-config. You will need to remove those commands from your running-config manually, but this time, the router should finally allow you to do that.
Don't forget to do this, though.
Best regards,
Peter
Register number how it relate to
dhcp
assing ?
If he have issue with register then router never run any config??
MHM,
Register number how it relate to dhcp assing ?
Adam's configuration register forced the limited broadcast address to be
0.0.0.0 instead of 255.255.255.255
DHCP servers usually don't listen to packets with destination IP address
0.0.0.0
- they listen to packets with destination IP address
255.255.255.255
This caused Adam's router to send out its DHCP Discover messages to a "broadcast" IP address that the DHCP server was not listening on, and it ignored them. That is why it never responded back. It was visible in the debugs Adam shared earlier - there are traces of the router sending out Discover packets but never getting back an Offer.
This is not true. Only specific bits in the configuration register - if set - will cause the router to ignore the NVRAM configuration. These are bits
15 (0x8000) and 6 (0x0040)
I have referred to a document describing the meaning of the bits in the configuration register above - this one: https://www.cisco.com/c/en/us/support/docs/routers/10000-series-routers/50421-config-register-use.html#toc-hId--612512991 - it's an interesting reading I can recommend.
Best regards,
Peter
Sure I will read it.
MHM
johnlloyd_13
Level 9
Level 9
hi,
can you do this?
interface FastEthernet0/0
no ip address dhcp
no ip broadcast-address 0.0.0.0
ip address dhcp client-id FastEthernet0/0
Hey John,
Good eye on the
A friendful comment: The
client-id Fa0/0
forces the DHCP client to identify itself by deriving its identity from the MAC address of the
Fa0/0
interface. This is required when the DHCP server is offering a stable IP to the client based on its identification. It is very safe to try this out, but if the DHCP server is not intentionally configured in advance for this identifier, then any should do, in which case the
client-id Fa0/0
is not required.
Let's see what Adam comes back with.
Best regards,
Peter
Thanks. I tried this, no difference.
You try what ?
The client ID must be same as what
dhcp server
use you need to contact ISP ask them the clinet ID format they use. Then config your router to send same client ID.
Hello buddy,
I touched that topic here already: https://community.cisco.com/t5/routing/interface-not-accepting-dhcp-address/m-p/4893494/highlight/true#M386912
Unless we have an evidence that this is even an ISP scenario and not a lab test, and that the ISP is expecting a specific DHCP client ID to allocate IP addresses, we cannot say that Adam "must" do anything. Let's wait for Adam to come back with more information.
Best regards,
Peter
Thanks I just clarify point here.
Have a nice summer
MHM
Right you are. Sorry i probably should of mentioned that this is indded a
test lab, connected to a cisco 3845. With the DHCP pool configured. I will
provide the request config in the next couple of days.
if it LAB then check
the interface receive the DHCP discover must be in same subnet of DHCP POOL, check the subnet and subnet MASK
also if you use excluded
255.255.255.255 or x.x.x.255
remove it.
and check again.
have a nice summer
MHM
as mentioned by others, you are running a very old IOS version, which requires the DHCP broadcast to go to
I somewhere recall that the global config command
no ip source-route disables ip directed broadcasts
can you try that command  and check if the interface still adds
ip directed-broadcast 0.0.0.0
to the interface ?
Hi Georg,
A very humble correction: The IOS on Adam's 2811 router is admittedly old but not tragically so - it's 12.4(15)T9. Back in my days at the university and NetAcad, we'd use even older versions (12.2, 12.3, 12.4) which would already be using
255.255.255.255, not 0.0.0.0, as the default limited-broadcast address
So I am very confident that the IOS version itself isn't the problem.
As for the
no ip source-route
that would be an interesting although unexpected correlation. Source routing is about the packet's sender explicitly putting the list of transit hops (up to 9) into the packet's header. But the packet still needs to be unicast... so I'm not sure why would that command have any bearing on the limited-broadcast address. But doesn't harm to test anyway, certainly!
I keep my hopes high about the config register and/or the complete configuration having something odd there.
Best regards,
Peter
