interface0/1/1 flapping /Significant interface CRC /input errors
AHMADJ
TenGigabitEthernet0/1/1 (21.1%)
248046 input errors, 208123 CRC, 0 frame, 0 overrun, 0 ignored
interface TenGigabitEthernet0/1/1
description +++ Connected to AM-CORE-B Te1/9 +++
ip flow monitor BRANCH_TUNNELS_MONITOR input
ip flow monitor BRANCH_TUNNELS_MONITOR output
ip address 10.231.24.58 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip ospf message-digest-key 1 md5 <removed>
ip ospf network point-to-point
ip ospf cost 11
load-interval 30
service-policy input AV-SCCM-SERVER-LIMIT-POLICY
service-policy output CENFS-BR-OUT-LIMIT-POLICY
6 Replies 6
Seb Rupik
HI there,
CRC errors are most likely caused by Layer1 issues (although can be Layer2 also). Swap the fibre cable reset the interface counters and check back after a short period of time.
cheers,
Seb.
I already swaaped the fiber and changed the cable and sfp
Ahmad jabali
What does the configuration and interface stats look like for AM-CORE-B Te1/9  ?
what device is connected on the other side ? Are the crc/input errors showing on the interface on the other side of the link as well ?
interface Ethernet1/9
  description +++ Connected to AM-MPLS-HUB-01 (ETC) Te0/1/1 +++
  no cdp enable
  flowcontrol receive on
  flowcontrol send on
  beacon
  ip flow monitor Netflow-Monitor-1 input sampler NF-Sampler-1
  ip flow monitor Netflow-Monitor-1 output sampler NF-Sampler-1
  no ip redirects
  ip address X.X.24.57/30
  ip ospf authentication message-digest
  ip ospf message-digest-key 1 md5 3 843ec881d2fe32374934a55d307c6bbf
  ip ospf cost 11
  ip router ospf 1 area 0.0.0.0
  no shutdown
Ethernet1/9 is down (linkFlapErrDisabled, port: error)
admin state is up, Dedicated Interface
  Hardware: 10000 Ethernet, address: e8ed.f338.0446 (bia e8ed.f33b.2938)
  Description: +++ Connected to AM-MPLS-HUB-01 (ETC) Te0/1/1 +++
  Internet Address is X.X.24.57/30
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec
  reliability 255/255, txload 1/255, rxload 1/255
  Encapsulation ARPA, medium is broadcast
  Port mode is routed
  auto-duplex, 10 Gb/s, media type is 10G
  Beacon is turned on
  Auto-Negotiation is turned off
  Input flow-control is on, output flow-control is on
  Auto-mdix is turned off
  Rate mode is dedicated
  Switchport monitor is off
  EtherType is 0x8100
  EEE (efficient-ethernet) : n/a
  Last link flapped 6d10h
  Last clearing of "show interface" counters 51w5d
  5029 interface resets
  Load-Interval #1: 30 seconds
    30 seconds input rate 0 bits/sec, 0 packets/sec
    30 seconds output rate 0 bits/sec, 0 packets/sec
    input rate 0 bps, 0 pps; output rate 0 bps, 0 pps
  Load-Interval #2: 5 minute (300 seconds)
    300 seconds input rate 0 bits/sec, 0 packets/sec
    300 seconds output rate 0 bits/sec, 0 packets/sec
  L3 in Switched:
    ucast: 2091981 pkts, 1383977706 bytes - mcast: 16498193 pkts, 4312241758 bytes
  L3 out Switched:
    ucast: 37248396 pkts, 9009221435 bytes - mcast: 0 pkts, 0 bytes
  RX
    2160817 unicast packets  18044266 multicast packets  839 broadcast packets
    20199042 input packets  5954344912 bytes
    0 jumbo packets  0 storm suppression packets
    0 runts  0 giants  0 CRC/FCS  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    48630582 unicast packets  3933970 multicast packets  14948 broadcast packets
    52569883 output packets  13724840322 bytes
    0 jumbo packets
    0 output error  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble  0 output discard
    0 Tx pause
Hello Ahmad,
the other device is likely a Nexus platform from interface naming.
On the Nexus side there are no input errors at all but in the past the port has flapped and you have disabled protection from flapping.
0 Rx pause
Have you tried to change the SFP optics also on the Nexus side?
Hope to help
Giuseppe
