internet acl
davec4351
I have a router configured on my lan, the source interface is gi0/0/0 and ip is obtained with via dhcp. My question is can I configure an acl without specifying the wan interface ip since the dhcp address changes every so often?
Here is a snip from my configuration to allow the internet for example of source wan interface
int gi0/0/0
ip nat outside
ip access-group 100 in
(access-list 100)
permit ip 96.255.180.0 0.0.0.255 any log     <---Can I create an acl without specifying the source wan network for internet access?
You do can configure this way.
 On the wan interface
Ip nat outside
On the LAN interface
Ip nat inside
For nat statement
Ip nat inside source  list 1 interface int gi0/0/0 overload
Ip access list standard 1 permit ip "local network"
"<---Can I create an acl without specifying the source wan network for internet access?"
The wan interface is not specified on the ACL. The local network is. Unless you are doing NAT from outside to inside.
Hello
Your current acl isn’t really doing any thing as its the only public ip address that is routable as i am assuming your internal lan subnets are all private RFC addressing and require NAT to access the internet.
As for specifying a source ip i would say it all depends on what you are trying to achieve with that acl - can you elaborate please?
Kind Regards
Paul
balaji.bandi
(access-list 100)
Hope this IP address is allocated from ISP to you, what is your LAN IP address ? Are you looking to NAT from inside to outside for Lan traffic to reach the internet right? so that ACL should be an Internal LAN address Translating to Public Routable IP or ISP-provided IP.
Hope that is what your intention here right ? or you looking outside to inside traffic ?
BB
