Internet connection lost after VPN established
pwolsza_wolfik1
It's common problem I think.
I do not  have connection after VPN through PPTP is established.
My VPN  connection was made according to this tutorial:
http://www.cisco.com/en/US/tech/tk827/tk369/technologies_configuration_example09186a00801e51e2.shtml
How to make  it work ??
7 Replies 7
When you connect via PPTP all traffic is going to be sent through the tunnel because it's not like an IPsec client where you can define split tunneling on the server side.
I remember there was an option under the windows client OS where you define gateway precedences and so make certain traffic go over the tunnel (not all). But if you succeed enabling split tunneling, is done on the client side (as opposed to the server side on IPsec).
Federico.
Yes, indeed. There is an option "use default gateway in remote site" disable this option helps but after that I'm loosing LAN network behind router.
shaun.cooney
In your VPN TCP/IP properties in Windows select the Networking Tab and select properties of TCP/IPv4.
Then select Advanced abd untick the default "Use Default Gateway on Remote Network"
Hope that helps
Yes, I know this option.
Unfortunately using it do not allow to connect to computers behind the router, what I could without enabling option in IP configuration on local host.
Edison Ortiz
As others mentioned, you need to disable the gateway of last resort for the VPN and if you want to add the specific networks sitting behind the router, you need to manually added to the host routing table with the 'route add' command.
This link has a tutorial:
http://www.howtogeek.com/howto/windows/adding-a-tcpip-route-to-the-windows-routing-table/
Edison
It worked but is this only the one way how I can configure it??
You can configure some scripting for that.
Please remember to rate helpful posts.
