Internet Failover via MPLS Cisco 2800
Adam Hudson
Currently I'm looking for a way to failover our internet connection from one site to another site over our MPLS line, should that internet connection go down.
My layout: Internet > Cable internet modem (Site B) > ASA 5510 (Site B) > 2821 Router (Site B) > MPLS Line > 2821 Router (Site A) > ASA5510 (Site A) > ISP provider internet router (Site A) > Internet
Facts:
Site B is the one with the internet issues.
The MPLS line is routed using BGP.
I think I'm on the right track with these posts:
https://supportforums.cisco.com/thread/2106249
http://brain.pobudz.net/?p=65
But there's not enough for me to go on. Any config help is appreciated.
Thanks in advance.
46 Replies 46
First off, big thank you to both John and Giuseppe for getting me this far!
John, I checked my sh ip route put my route inside in. The internet connection over the MPLS was choppy before, now it's a little less choppy. I ping yahoo from a computer on Site B, I get 4 sucessful pings back, then 2 time outs, then it repeats, so at least it's constant.
Here's my tracert from that computer on Site B:
Tracing route to google.com [74.125.225.35]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms
  2     *        *      244 ms
  3     *        *      120 ms
  4     *        *       23 ms
  5     *        *       48 ms
  6     *        *       50 ms  cr81.ipsin.ip.att.net [12.122.152.154]
  7    45 ms    35 ms    35 ms  cr1.cgcil.ip.att.net [12.122.152.138]
  8    59 ms   122 ms   107 ms  gar2.clboh.ip.att.net [12.122.99.49]
  9   143 ms   112 ms   196 ms  12.249.24.6
10     *        *      105 ms  209.85.254.120
11     *        *       64 ms  209.85.250.28
12     *        *      456 ms  ord08s06-in-f3.1e100.net [74.125.225.35]
Trace complete.
Does that tell you anything? It might still something in my ASA, I'm thinking about where I would check to see if some of those packets aren't being let in on the ASA. Not sure right now, researching...
Adam,
I'm more curious as to why you're timing out here and why the latency is so high at the router that you're local to:
  2     *        *      244 ms
  3     *        *      120 ms
  4     *        *       23 ms
  5     *        *       48 ms
I know you diagrammed the topology up top, but can you do a visio diagram showing us how this is laid out?
HTH, John *** Please rate all useful posts ***
Hopefully it's attached to this post.
Adam,
That's a tremendous help; thank you. How are you testing this now? Are you actually bringing the site down? When you're doing your ping, where does the default route point on site B's router? Is it going to the ASA in site B or does it point to site A's router (actually it will point to the MPLS PE)?
John
Site B is currently down, the current internet facing port Site B's ASA is bad. This is one of the reason's I'm trying this. Also, when we move the internet to a good port on ASA B, I want to keep this in place in case the internet goes out again.
The default route on site B router points to it's MPLS interface, which is keying me off that the IP SLA did make the switch.
Do you get the same responses if you ping a host in site A?
From Site A the internet works fine.
I'm sorry...I meant do you get the same problem when you ping a host in site A from the host in site B. Try a traceroute to see if you get the same type of result.
Pings and traceroutes from Site B to Site A run fine. So far it seems to be isolated to internet traffic from Site B out through Site A's internet.
Hmm...can you post the nat configuration on the ASA and the route back to site B? Also, does your site A internet router do anything with natting or anything like that or is it strictly the ASA?
John,
Question 1: This is everything that doesn't pertain to the DMZ, which has no play in this:
access-list inside_nat0_outbound extended permit ip any 255.255.255.0
nat-control
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 255.255.255.0
nat (inside) 1 0.0.0.0 0.0.0.0
route outside 0.0.0.0 0.0.0.0 1
route inside 255.255.255.0 1
Question 2: As far as I know, no NATting on the internet router, we certainly didn't ask them to.
Adam,
This should be pointing to your router (2821 interface) that connects to the ASA.
The above line could be causing an issue only because you're basically telling the ASA to not nat anything going to this subnet. What you should be doing here is tying down the subnets that are in your dmz and not natting to those. Everything else should be natted. Your "nat (inside) 1 0 0" line matches all traffic, so the "nat ... site b subnet" is really unnecessary.
So, what I would do is the following:
Let's say your DMZ is 192.168.18.0/24.
Try removing:
and putting in:
access-list inside_nat0_outbound extended permit ip 192.168.18.0 255.255.255.0 255.255.255.0
Obviously you'll want to cover all of your DMZs if you have more than one.
Then you can remove the nat (inside) 1 line.
You also need to change your static route on the ASA to point to the router as stated above.
Ok, trying to apply this to my other site (Site C) because they're having internet problems of their own. Should be set up the exact same way Site B is. Here's the commands I put in:
Commands
Site C router#
ip sla monitor 1
type echo protocol ipicmpecho
frequency 5
ip sla monitor schedule 1 life forever start now
track 1 rtr 1 reachability
ip route 0.0.0.0 0.0.0.0 track 1
ip route 0.0.0.0 0.0.0.0 254
Site A router#
router bgp
network 0.0.0.0
Site A firewall#
Results
From Site C I ping a site like yahoo. I get 9 replies, 2 timeouts. The pattern repeats.
So close, but there's still some problems. Any help is greatly appreciated.
Thanks in advance.
tracert results from a pc on Site C:
  1    <1 ms    <1 ms    <1 ms
  2     3 ms     3 ms     3 ms
  3    18 ms    19 ms    19 ms  cr81.okbil.ip.att.net [12.123.210.246]
  4    17 ms    19 ms    19 ms  cr2.cgcil.ip.att.net [12.122.1.194]
  5    20 ms    19 ms    20 ms  cr1.cgcil.ip.att.net [12.122.2.53]
  6    19 ms    15 ms    15 ms  cr81.ipsin.ip.att.net [12.122.152.137]
  7     *        *        *     Request timed out.
  8    14 ms    13 ms    13 ms
  9    14 ms    14 ms    14 ms
10     *        *       27 ms  gi2-10.na41.b021117-0.ind01.atlas.cogentco.com [38.109.176.9]
11    15 ms    15 ms    27 ms  te4-2.3805.ccr01.ind01.atlas.cogentco.com [38.20.52.225]
12    18 ms    18 ms    18 ms  te3-1.ccr01.cvg02.atlas.cogentco.com [154.54.84.165]
13    20 ms    20 ms    20 ms  te3-1.ccr01.cmh02.atlas.cogentco.com [154.54.84.174]
14    22 ms    22 ms    38 ms  te4-8.ccr02.cle04.atlas.cogentco.com [154.54.28.169]
15    26 ms   217 ms   204 ms  te3-2.ccr01.pit02.atlas.cogentco.com [154.54.30.6]
16     *        *        *     Request timed out.
17    36 ms    36 ms    36 ms  te0-0-0-2.ccr21.iad02.atlas.cogentco.com [154.54.1.42]
18    36 ms    36 ms    36 ms  te2-7.mpd01.iad01.atlas.cogentco.com [154.54.31.226]
19    35 ms    35 ms    35 ms  yahoo.iad01.atlas.cogentco.com [154.54.11.114]
20    35 ms    35 ms    35 ms  ae-6.pat2.dce.yahoo.com [216.115.102.176]
21    69 ms    69 ms    69 ms  ae-6.pat2.dax.yahoo.com [216.115.96.21]
22    65 ms    65 ms    69 ms  ae-1-d111.msr2.mud.yahoo.com [216.115.104.103]
23     *        *        *     Request timed out.
24    66 ms    69 ms    70 ms  te-8-1.fab2-a-gdc.mud.yahoo.com [209.191.78.141]
25    69 ms    63 ms    69 ms  te-8-2.bas-c1.mud.yahoo.com [209.191.78.173]
26    69 ms    63 ms    70 ms  ir1.fp.vip.mud.yahoo.com [209.191.122.70]
Trace complete.
Ok, so we're getting somewhere now. Did some pinging around my network:
Site C PC > Site C Router: pings good
       "        > Site C MPLS interface: pings good
      "         > Site A MPLS interface: pings good
      "         > Site A inside ASA interface: pings good
      "         > Site A outside ASA interface: all pings dropped
      "         > Site A ISP provided router: guess what....9 replies, 2 drops, repeat
The problem comes once those packets get outside the ASA.
