Internet Failover via MPLS Cisco 2800
Adam Hudson
Currently I'm looking for a way to failover our internet connection from one site to another site over our MPLS line, should that internet connection go down.
My layout: Internet > Cable internet modem (Site B) > ASA 5510 (Site B) > 2821 Router (Site B) > MPLS Line > 2821 Router (Site A) > ASA5510 (Site A) > ISP provider internet router (Site A) > Internet
Facts:
Site B is the one with the internet issues.
The MPLS line is routed using BGP.
I think I'm on the right track with these posts:
https://supportforums.cisco.com/thread/2106249
http://brain.pobudz.net/?p=65
But there's not enough for me to go on. Any config help is appreciated.
Thanks in advance.
46 Replies 46
Currently looking up some forms of packet capture to see if that will help me pinpoint the issue.
Found the packet tracer tool on the ASDM, trying to trace ICMP traffic...I found the ICMP code I need, but I cannot find any reference on the ID number/letter I need.
I put in an ID of 1, that seemed to get it going. Here's my results, everything looks good until the NATing, then this step gets a red X:
Type - NAT  Action - DROP
Config
nat (inside) 1 255.255.255.0
nat-control
match ip inside 255.255.255.0 outside any
dynamic translation to pool 1 ( [Interface PAT] )
translate_hits = 1747, untranslate_hits = 96
Checking it again this morning I'm getting the "4 good pings, 2 bad pings" pattern I was getting with the other site. At least the issue is consistent. Still checking on why that nat statement would cause a problem. Although some posts I've read claim packet tracer doesn't always point to the correct cause of the problem so I may be barking up the wrong tree.
Currently looking at other ways to debug/troubleshoot NAT if it is indeed a problem with my translation.
More confusing results, I don't see any drops here. Results from a packet trace run at the CLI:
SiteAFirewall(config)# packet-tracer input outside icmp 8 0
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Additional Information:
Found no matching flow, creating a new flow
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in      255.255.255.240 outside
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group outside_access_in in interface outside
access-list outside_access_in extended permit icmp any any
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
Phase: 6
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
Phase: 7
Type:
Subtype:
Result: ALLOW
Config:
Phase: 8
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 9
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 22638033, packet dispatched to next module
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: allow
As you can see in my attached file, I'm looking at rules 10 and 11. Shouldn't those be outside and inside, not outside and dmz. Is this my problem?
Trying some captures on the outside and inside interfaces, hopefully this will shed some light on the problem.
Here's my capture code:
Code
access-list capturetest permit ip host host 4.2.2.2
access-list capturetest permit ip host 4.2.2.2 host
access-list capturetest permit icmp host host 4.2.2.2
access-list capturetest permit icmp host 4.2.2.2 host
capture cap1 access-list capturetest interface inside
capture cap2 access-list capturetest interface outside
Results
sh capture cap1
1: 17:56:00.801746 > 4.2.2.2: icmp: echo request
   2: 17:56:00.811054 4.2.2.2 > : icmp: echo reply
   3: 17:56:01.802845 > 4.2.2.2: icmp: echo request
   4: 17:56:01.811969 4.2.2.2 > : icmp: echo reply
   5: 17:56:02.803882 > 4.2.2.2: icmp: echo request
   6: 17:56:02.813129 4.2.2.2 > : icmp: echo reply
sh capture cap2
0 packet captured
0 packet shown
This makes me lean strongly towards something being wrong at the ASA concerning the outside interface. Has anyone else seen something like this? Any help is appreciated.
Thanks in advance.
Something else to mention from one of my earlier posts, nat control is currently turned on on my ASA, someone else who's taken a look at this issue mentioned that might cause some issues.
Turning off nat-control had no effect.
For those curious but have just skimmed the replies, this is my clearest lead on what the problem is but I haven't really been able make heads or tails of it.
These are the results when I run packet tracer on the ASDM, from a PC on Site C, going out to the ISP's router on Site A:
Config
nat-control
If that nat (inside) line is the problem, I'm not sure what to put there instead.
Results of "show nat" on Site A ASA pertaining to Site C traffic:
  match ip inside 255.255.255.0 dmz any
    static translation to
    translate_hits = 0, untranslate_hits = 0
  match ip inside 255.255.255.0 inside any
    dynamic translation to pool 1 (No matching global)
    dynamic translation to pool 1 ( [Interface PAT])
    translate_hits = 62, untranslate_hits = 0
  match ip inside 255.255.255.0 management any
If I was going to try and interpret this I would say it seems like there's a problem with the ASA translating my Site C addresses using Site A's pool. Not sure why, it's not like the ASA can only translate one internal subnet.
Subnets along with sanitized config for Site A ASA for those that want to take a look:
Site A:
11.2.1
11.1.1
11.2.100
11.2.70
173.16.1
Site B:
11.2.2
173.18.2
Site C:
11.8
After running over the issue with some other folks it looks like the ASA config is good. We'll be going over the router configs next.
