internet failover with single 3750 switch
saqiibiqbal
Hello All,
i need your help in configuring internet failover on Cisco 3750 switch. what i have is:
- 1 Cisco 3750 switch
- 3 Cisco 2970 Switches that i want to use as distribution on LAN.
- have 2 internet from different ISP's.
- want to have 4 VLAN's for different departments.
- want to route traffic of 2 departments on ISP 1 and other 2 departments on ISP 2.
- want to configure 3750 as a failover as well that if ISP1 goes down all traffic shifts to ISP2 and vice versa.
please suggest how can i achieve this task.
Thanks.
5 Replies 5
MANI .P
Hi  saqiibiqbal ,
   My undestanding  you have daul ISP's ISP1 & ISP2 . Internal user's need to access the internet ISP'1 as the primary and ISP'2 as the Backup .
 Follow the below steps  .
01. Create the VLAN SVI's for each subnet's
eg :  10.xx.xx.xx  for vlan 10 , 20.xx.xx.xx for vlan 20
02. To create the access list to permit
access-list 10 permit 10.xx.xx.xx XX.xx.xx.255
access-list 20 permit 20.xx.xx.xx xx.xx.xx.255
access-list 60 Permit any any
03. to create the Route map
Route-map R_MAP permit 10
match ip address 10
set ip next-hop ISP'1 WAN IP address
Route-map R_MAP permit 20
match ip address 10
Route-map R_MAP permit 30
match ip address 60
set ip next-hop ISP's WAN IP address
04 . to apply the rotue policy in SVI's interface
eg : int vlan 10
       ip plicy route-map R_MAP
       int vlan 20
i hope it would be useful....
Thanks for the reply.
actually i want to route traffic of vlan 10 & 20 to ISP1 and traffic of vlan 30 & 40 to ISP 2.
in case either of the ISP goes down i want to route the traffic of all vlan's on the ISP that is up.
Thanks.
simple .
"actually i want to route traffic of vlan 10 & 20 to ISP1 and traffic of vlan 30 & 40 to ISP 2. "
By default VLAN 10 , VLAN 20 traffic thru ISP1 . --> Incase ISP1 Down--> traffic go thru ISP2
By Default VLAN 30 , VLAN 40 traffic thru ISP2  --> Incase ISP2 Down--> traffic go thru ISP1
"Load balancing & Auto failover.
01. create a ACL for VLAN's IP Pools .
access-list 10 permit 10.0.0.0 0.0.0.255
access-list 20 permit 10.0.0.0 0.0.0.255
 access-list 30 permit 10.0.0.0 0.0.0.255
access-list 40 permit 10.0.0.0 0.0.0.255
access-list 50 permit any any
02. create a route MAP & to match the ACL & set action.
Route-map ISP1_Allow permit 10
match ip address 10
set ip next-hop (ISP1 Pub IP )
Route-map ISP1_Allow permit 20
match ip address 20
Route-map ISP1_Allow permit 50
match ip address 50
set ip next-hop (ISP2 Pub IP )
Route-map ISP2_Allow permit 30
match ip address 30
Route-map ISP2_Allow permit 40
match ip address 40
Route-map ISP2_Allow permit 50
match ip address 50
03. Apply the route-map in interface
Interface vlan 10
ip policy route-map ISP1_Allow
Interface vlan20
Interface vlan 30
ip policy route-map ISP2_Allow
Interface vlan 40
Hope it's useful .
First of all sorry for the delay as i was not able to test this scenario. i have started working on this and will let you know once i finished.
Thanks.
hello,
 i have tried the above configuration but unfortunetly it is not working. i am able to ping google from the switch but when i try to ping google from the workstation that is attached to one of the vlan it is unable to ping google or the gateway.
what i understand is that traffic is not able to go out of the switch. everything is working fine internally (inside switch).
any more suggestions?
Thanks.
