%STORM_CONTROL-3-FILTERED: A Unicast storm detected on
Goodday,
For some days i'm getting the following "error"  message on the switch
%STORM_CONTROL-3-FILTERED: A Unicast storm detected on GI0/47  A packet filter action has been applied
Port 0/47 is connected to a another switch with the following stormcontrol configuration.
storm-control broadcast level 30.00
storm-control multicast level 40.00
storm-control unicast level 70.00
my question is how to troubleshoot on the switch which is connected to GI0/47  which device is causing the unicast traffic.
Thanks in advance
Topcu
Vinit Jain
Hello Topcu
If you are continuously facing this problem, then the best way to investigate this issue is to perform a sniffer capture. Configure a span session on the switch and redirect the traffic coming on port gi0/47 towards a port connected to a PC having wireshark. This will help understand from where you are receiving the traffic and what is the src mac for that frame.
I would also like to know what platform are you having. Could you please share the show version output from the switch.
Vinit
--Vinit
Thanks for your reply.
and here you are the Show version output of the switch is causing the unistorm messages.
Cisco IOS Software, C2960 Software (C2960-LANBASE-M), Version 12.2(50)SE, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Fri 27-Feb-09 23:25 by weiliu
Image text-base: 0x00003000, data-base: 0x01200000
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
SZZ-01-SWA-02 uptime is 13 weeks, 2 days, 6 hours, 34 minutes
System restarted at 05:36:54 UTC Sun Aug 16 2015
System image file is "flash:c2960-lanbase-mz.122-50.SE.bin"
cisco WS-C2960-48TT-L (PowerPC405) processor (revision E0) with 61440K/4088K bytes of memory.
Processor board ID
Last reset from power-on
2 Virtual Ethernet interfaces
48 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:22:0C:BA:87:80
Motherboard assembly number : 73-10391-05
Power supply part number : 341-0097-02
Motherboard serial number : FOC1224084P
Power supply serial number : AZS1223041L
Model revision number : E0
Motherboard revision number : A0
Model number : WS-C2960-48TT-L
System serial number : FOC1224A0EY
Top Assembly Part Number : 800-27222-04
Top Assembly Revision Number : A0
Version ID : V04
CLEI Code Number : COM3H00BRC
Hardware Board Revision Number : 0x02
Switch Ports Model SW Version SW Image
* 1 50 WS-C2960-48TT-L 12.2(50)SE C2960-LANBASE-M
Thanks in advance,
You can also configure that specific interface to send snmp traps to a server as well as Vinit solution. Please take a look at the link below
interface GI0/47
Storm-control action trap
http://packetlife.net/blog/2008/nov/27/storm-control/
Masoud
