Internet for public LAN IP and Private WAN IP
titusroz03
HI All,
My ISP have provided the below config for a DIA circuit.
WAN Ips are private ones and LAN subnet is public(Subnets are hided in image for security)
I can reach the internet from the LAN public IP(ISP) provided from ISP if I have static route pointed to their WAN ip as below
But if I am trying to reach internet from my internal LAN ip(192.168.2.0/24) it's not working. I have NAT overload were my LAN ip(192.168.x.x) is insidelocal and LAN public IP provided from ISP as Insideglobal. Can any one provide suggestions to make this work..?
Do I need to make sure on routing of my internal LAN..?
Devaa
I believe you should config something like this. Your outside interface will have private 10.x IP given by ISP, which makes sense with your default route.
int g0/0/2.4
 ip add 10.104.150.210 255.255.255.252
Once you make the above change, try to ping 10.104.150.209 (if allowed from ISP side)
! Configure proper START IP (A) and End IP (B) and subnet mask as given by ISP
ip nat pool NAT-POOL 202.X.X.A 202.X.X.B netmask 255.255.255.0
ip nat inside source list 10 pool NAT-POOL overload
Above config should fix your issue. Let me know if you observe any issues.
9 Replies 9
Devaa
Could you please share inside interface, outside interface and NAT config (mask your public IP for security)?
Ip Nat Outside
IP Nat inside
NAT config
M02@rt37
Hello @titusroz03
Please verify NAT translations using
#show ip nat translations command
When you try "to reach internet" from you LAN.... you test with icmp or webpage?
Best regards
NO nat Translations are viewed since it hits route first and nat next.
Best regards
Yes...ICMP from router tested as below
Ok @titusroz03
So please check your ACL #10. Ensure that this ACL match tou LAN Netwok.
Best regards
Devaa
int g0/0/2.4
Thank you very much..It worked as expected
