Internet lease Line
netview69
I hv 2 MB Internet lease Line. ISP has given me public IP of serial port for router, Gateway public IP & six public IP.
Now I wants to configue Internet for our LAN(private ip). How to do this pls guide me in configuration of router.
Its urgent for me.......
Ak
10 Replies 10
Edison Ortiz
Please take a moment to read this article:
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094e77.shtml
HTH,
__
Edison.
Please rate helpful posts
Hi Edison,
If u tell me step by step commands its very helpfull for me pls do needfull.
Regds
AK
U can see in that article, which example is matching to ur case and then use the steps mentioned their.
We dont have idea how ur netowrk is connecetd.
See ISP gave me one public IP for serial int & one for gayeway. So I put that public ip to serial int & gave one privte ip to ethernet.
ip nat inside for ethernet
ip nat outside for serial intface
ip access-list 1 permit any
ip nat inside source list 1 interface Serial0/0 overload
ip route 0.0.0.0 0.0.0.0 gateway ip
This all I configured on router but internet is not working in LAN. Pls help me.
Regds
AK
Router(config)#ip nat pool netview xxx.xxx.xxx.xxx(First IP from the pool ISP gae you) xxx.xxx.xxx.xxx(last IP from the pool ISP gave you) netmask (whatever IP mask ISP gave you)
(I used pool name as netview you can use any name u want to give)
Router(config)#access-list 1 permit any
Router(config)#ip nat inside source 1 (access-lisr number u have used 1) pool netview(which is assume u can write as per udefine above)
Remove this
Add those 3 command and delete i told u and let me know how is it going.
paste your sh run after u have done config. u can hide ur IP address and password etc
Viyuan,
My router hv IOS 11.3 this.......
Router(config)#ip nat pool netview........ command is not working.
its giving error on pool
Router(config)#ip nat inside source 1 pool netview
its giving error on 1
How to do????? pls help me out. pls tell soon
Waitinggggg
Regds
AK
Before proceeding, I highly recommend upgrading the IOS on that router as soon as possible.
You are running a very old IOS version that is exposed to several security vulnerabilities. Placing this device facing an internet connection wouldn't be ideal for this implementation.
Once you do that, follow the link I posted originally and all the commands listed on the link should work.
HTH,
__
Edison.
If ur router dont take pool command then ur configuration
is correct instead of permit any u can try your Private IP address range.
ping from your LAN to gateway IP.
check sh ip nat translation command
One more thing you can check, is ISP have done configuration from ISP router to your router.
Viyuan,
Boss if I do this config Internet is working
ethernet...public Ip
Serial.... Public Ip
Only these three commands..Internet is working n pinding to DNS, Gatway etc etc
But when I put do this config internet is not working on LAN
ethernet....private IP
ip nat inside ethernet
ip nat out side serial
How I can ping from LAN IP to gatway???? I will not ping. pls give me solution. I dont hv new IOS. As I told u my router hv 11.3 IOS
REgds
AK
Spoiler
hi ,
I have one problem and little bit confuse
For only connectivity between HQ to branch office by leased line not internet required  still we need public IP on serial interface..
