Intervlan Routing in Cisco C9300 switch
Mit_har
I want to enable the intervlan routing in Cisco C9300 switch. Does
IP routing
command is enough to do this or more config I have to do?
In your config you have A and B switch ip
default-gateway
configured to VIP IP address -&nbsp
10.91.4.1
admin switch also the same
10.91.4.1
if the switch looking to have Layer 3 routing on A and B and admin switch
change to
ip routing x.x.x.x x.x.x.x .xxxx
(removing
default gateway
to work)
also post from A and B and admin below command outcome
show ip route
show ip interface brief
show standby brief
how are you testing - Inter-vlan routing ? (connecting PC in admin switch in VLAN4 - and what gateway PC has when you configured in VLAN 4 ?)
have done traceroute to IP address where is that stuck ?
BB
12 Replies 12
M02@rt37
Hello @Mit_har,
Considering L2 and L3 vlan config is OK, yes, do
ip routing
command for inter-VLAN routing.
Best regards
Thanks. I did the
IP routing
still its not working for intervlan routing.
Attached is the core switch A and B config along with Layer 2 switch config for end device connection. We did HSRP configuration between vlan 4 and 5. Rest of the HSRP config, I will do later. Please suggest if there any changes I have to do.
@Mit_har
What is the license ?
Best regards
Hi, Core switch License:
network-advantage (C9300X-12/24Y Network ...) 2 IN USE
dna-advantage (C9300X-12/24Y DNA Adva...) 2 IN USE
default-gateway
10.91.4.1
10.91.4.1
change to
(removing
default gateway
to work)
show ip route
show standby brief
BB
Here Admin switch is acting as a layer 2 switch which is connected to Core switch A and B. We have connected the end devices on admin switch. Do I still need to do IP route as suggested?
Please suggest what
Ip route
I should apply and on which switch.
If the admin switch acting as Layer 2 - that is ok
default gateway
If the admin switch connected to Switch A and B  (if the Switch A and B connected using Layer 2 Link) admin switch only have 1 path due to STP blocking here.
I have configured the default gateway for vlan 4 is 10.91.4.1 and vlan 5 is 10.91.5.1 in individual pcs. Both PC's can reach there own default gateway.
Can PC VLAN 4 can ping 10.91.5.1 ?
Can PC VLAN 5 can ping 10.91.4.1 ?
how are you testing - Inter-vlan routing ?  from VLAN4 PC to VLAN5 PC ?
Does the PC have Firewall have you removed and tested ?
BB
HI, My testing as below.
Can PC VLAN 4 can
ping 10.91.5.1
PC VLAN 4 is able to
ping 10.91.5.21
(Core switch A address), not
10.91.5.1
(Virtual IP for VLAN 5) or
10.91.5.22
(Core Switch B address)
Can PC VLAN 5 can
ping 10.91.4.1
PC VLAN 5 is able to
 ping 10.91.4.1
(Virtual IP address for VLAN 4) , not
10.91.4.21
(Core switch A address) or
10.91.4.22
(Core Switch B address).
Yes, I am trying to ping VLAN 4 PC to VLAN 5 PC or vide versa but not able to ping.
Firewall is disabled for both PC.
I did the traceroute from another Layer 2 switch 2
(default gateway for this switch is 10.91.4.1)
to VLAN 5 PC (connected on Admin Switch 1), it is showing till core switch A address. not going forward.
I have not did any
Ip route
in both core switches as
IP routing
command is enough for intervlan routing.
@balaji.bandi M02@rt37
I was able to resolve this. The problem was with the PC
default gateway
I have 2 ethernet adopter, one connection was for Internet and another was for switch testing. I changed the priority on the Ethernet 2 to follow the
default gateway
of switch testing and its works.
I am thankful to both of you to guide me on this problem.
You're welcome @Mit_har
Best regards
@Mit_har,
you have to troubleshoot a bit further.
PCs ping their own Gateway ?
Please provide us outputs that @balaji.bandi ask.
Thanks.
Best regards
M02@rt37 @balaji.bandi
Please find the attached output for
 show ip route, show ip
interface brief and show standby brief.
default gateway
I have removed the IP
default-gateway 10.9.4.1
from the Core switch A and B. Only Admin switch have IP
default-gateway to 10.91.4.1
Could you please suggest What Ip route I have to configure here in core switches?
change to
(removing
default gateway
to work) as suggested before.
