InterVLAN routing
Hello. I have been practicing in interVLAN routing and faced trouble.
I have GNS3 and my topology looks like this:Capture.PNG
Device MY_PC is cloud connected to virtual interface on my PC. I can ping gateway subinterface of all subnets. Although I can ping PC2 from PC1. Can ping VLAN 10 from my pc (using CMD) and gateway but not other devices or even router subinterfaces.
Here are configurations:
Router:
Current configuration : 1331 bytes
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
ip tcp synwait-time 5
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1.10
encapsulation dot1Q 10
ip address 192.168.10.254 255.255.255.0
interface FastEthernet0/1.20
encapsulation dot1Q 20
ip address 192.168.20.254 255.255.255.0
ip helper-address 192.168.40.1
interface FastEthernet0/1.30
encapsulation dot1Q 30
ip address 192.168.30.254 255.255.255.0
interface FastEthernet0/1.40
encapsulation dot1Q 40
ip address 192.168.40.254 255.255.255.0
interface FastEthernet1/0
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
no cdp log mismatch duplex
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
Switch:
Current configuration : 1795 bytes
! Last configuration change at 22:40:09 UTC Sat Apr 18 2020
version 15.2
service compress-config
hostname SW1
boot-start-marker
boot-end-marker
logging discriminator EXCESS severity drops 6 msg-body drops EXCESSCOLL
logging buffered 50000
logging console discriminator EXCESS
no aaa new-model
no ip domain-lookup
ip cef
no ipv6 cef
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
interface Ethernet0/0
switchport trunk allowed vlan 10,20,30,40
switchport trunk native vlan 99
switchport mode trunk
interface Ethernet0/1
switchport access vlan 10
switchport mode access
interface Ethernet0/2
switchport access vlan 20
interface Ethernet0/3
switchport access vlan 30
interface Ethernet1/0
switchport access vlan 40
interface Ethernet1/1
interface Ethernet1/2
interface Ethernet1/3
interface Ethernet2/0
interface Ethernet2/1
interface Ethernet2/2
interface Ethernet2/3
interface Ethernet3/0
interface Ethernet3/1
interface Ethernet3/2
interface Ethernet3/3
interface Vlan1
no ip address
shutdown
interface Vlan10
ip address 192.168.10.253 255.255.255.0
ip default-gateway 192.168.10.254
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
13 Replies 13
Martin L
What is MY_PC default gateway? is it Router's IP of 192.168.10.254?
Here is output of ipconfig and pinging default gateway of MY_PCs subnet and default gateway of another subnet.
Hi @DavitiAbesalashvili
Occasionally, PC firewalls block pinging of external networks.
Check that the firewall of your S.O. it is not blocking the ping.
briefly disabling PC firewall during testing is good idea
That are results with disabled firewall.
I see you are using VMNet10 as a connection to your GNS3 Cloud but not Microsoft Loopback interface. In the past, I always use MS Loopback interface to connect to GNS3 and were able to ping GNS3 device via CMD of my Host PC.
Please check GNS3 doc or forums which way you should use it. I think only way is via MS Loop and not via VMnet.
Regards, ML
**Please Rate All Helpful Responses **
Can you share route print from your machine? And try doing capture on your pc and start a ping from router.
Hello
You a missing the native vlan on the router, by default the physical interface of the subinterfaces would be it (vlan 1) but as you have stated a native vlan 99 you need to create this on your router
RTR
conf t
int fa0/1.99
encapsulation dot1Q 99 native
Kind Regards
Paul
Changed VMware virtual interface to MS loopback and have same issue. can ping router;s subinterface in my subnet but not another one. When I change it to VPC I can ping everything. Guess something is wrong with interaction between MS and GNS3
did you disable Firewall on Host PC for testing? if still fails; save and exit. Create new project with MS Loop to Cloud to GNS3 Router without IOU switch.
Check GNS3 forums for help. Things might be different if you use GNS3 Server.
Regards, ML
Yes, firewall was disabled, tried config changes, advised here, and Vmware forum is quiet, couldn't figure out thing. Same works with use of VPCs.
  • Use a native vlan dot1q on the router and check if that works.
Try using a normal PC instead of cloud and check if the ping works.
Please do not hesitate to click the STAR button if you are satisfied with my answer.
