Problems with 'Reliable Static Routing' using rtr
I have a 1721 router with 3 nics.
f0 - LAN
e0 - primary
e1 - secondary
eo & e1 plug into two different firewalls and then off to the internet using two different ISP'S. The idea was to provide some degree of failover between to the two ISP's.
I decided to use 'reliable static routing' which should replace the default-gateway with a floating default-gateway to the secondary link.
I configured rtr to poll a public internet address which if failed to respond would replace the default-gateway. The problem I have is that every time I enable this rtr and tracking feature, it fails to see the public internet address, so I'm always in a failed over state.
If I disable rtr and tracking, I can ping the public address through both primary & secondary links no problem.
As I mentioned e0 & e1 plug into two differnet firewalls, firewalls are performing NAT and ports are completey open on each firewall.
I'm scracthing my head and don't understand why traking can't see the public address. Here is a copy of my config.....
LAB1#sh run
Building configuration...
Current configuration : 1250 bytes
version 12.4
hostname LAB1
boot-start-marker
boot-end-marker
enable secret 5 $1$5FeV$T4LY/smzKpMWtgee4OmvK.
enable password cisco
no aaa new-model
resource policy
memory-size iomem 25
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip cef
ip sla monitor 1
type echo protocol ipIcmpEcho 10.100.106.10
timeout 1000
threshold 2
frequency 3
ip sla monitor schedule 1 life forever start-time now
track 123 rtr 1 reachability
interface Ethernet0
ip address 192.168.225.2 255.255.255.0
half-duplex
interface Ethernet1
ip address 192.168.99.66 255.255.255.0
half-duplex
interface FastEthernet0
ip address 192.168.229.2 255.255.255.0
speed auto
full-duplex
ip local policy route-map MY_LOCAL_POLICY
ip route 0.0.0.0 0.0.0.0 192.168.225.1 track 123
ip route 0.0.0.0 0.0.0.0 192.168.99.1 254
no ip http server
access-list 101 permit icmp any host 10.100.106.10 echo
route-map MY_LOCAL_POLICY permit 10
match ip address 101
set interface Null0
set ip next-hop 192.168.99.1
control-plane
line con 0
line aux 0
line vty 0 4
password cisco
login
end
LAB1#
No probs... I did not even think of checking it at first !
The point of pushing it out through the primary interface is so that you will know for certain when that link is down since the ping cannot go out any other way.
Pls do rate the posts if you thought they were useful.
Paresh
8 Replies 8
pkhatri
Level 11
Level 11
I believe the problem is in your route-map. Change it so that it looks like the following:
set interface Null0
i.e. add the 'set ip next-hop' command first followed by 'set interface null0'
Hope that helps - pls rate the post if it does.
Paresh
it doesn't seam to matter what order I enter the commands, the null 0 statement always appears before the next hop command.
I just deleted the route map and re-created it and still it appears before next-hop !
Actually, I must take back what I posted earlier.. that was a bit of a red herring...the 'set ip next-hop' will always take priority.
I suggest you enable 'debug ip policy' with the local policy applied and then attempt to ping 10.100.106.10. That will tell you whether the local policy is doing its job.
Paresh
Just deleted everything and started again, lost count of how many time I've done that.
I added a bit to the end of the rtr statement so it forces traffic out of the appropriate interface and chose a public ip just a couple of hops away.
type echo protocol IpIcmpEcho 65.193.201.129 source-ipaddr 192.168.225.2 (e0)
still got the same problem and debug shows map is working I think
*Mar 1 17:00:14.311: IP: s=192.168.225.2 (local), d=65.193.201.129, len 64, pol
icy match
*Mar 1 17:00:14.311: IP: route map MY_LOCAL_POLICY, item 10, permit
*Mar 1 17:00:14.311: IP: s=192.168.225.2 (local), d=65.193.201.129 (Ethernet1),
len 64, policy routed
*Mar 1 17:00:14.311: IP: local to Ethernet1 192.168.99.1
*Mar 1 17:00:17.311: IP: s=192.168.225.2 (local), d=65.193.201.129, len 64, pol
icy match
*Mar 1 17:00:17.311: IP: route map MY_LOCAL_POLICY, item 10, permit
*Mar 1 17:00:17.311: IP: s=192.168.225.2 (local), d=65.193.201.129 (Ethernet1),
I confident it's something to do with route-map or policy because if I remove these, I can ping public internet addresses through either link.
here's my current config
Current configuration : 1275 bytes
version 12.4
hostname LAB1
boot-start-marker
boot-end-marker
enable secret xxxx.
enable password xxxx
no aaa new-model
resource policy
no mmi pvc
ip cef
ip sla monitor 1
type echo protocol ipIcmpEcho 65.193.201.129 source-ipaddr 192.168.225.2
timeout 1000
threshold 2
frequency 3
interface Ethernet0
half-duplex
interface Ethernet1
half-duplex
speed auto
full-duplex
no ip http server
access-list 101 permit icmp any host 65.193.201.129
set interface Null0
control-plane
line con 0
line aux 0
line vty 0 4
password xxxx
login
end
LAB1#
Hey,
I think I know what the issue is... the next-hop address you specify in the route-map should be the next-hop address of the primary interface. You have configured it to be the next-hop on the backup interface. You have to set it to be 192.168.225.1.
Hope that helps,
Paresh.
Your the man ! You've made my day !
It must be a typo in the Cisco document as this specifies the secondary interface as next-hop. My understanding of this was for next hop if primary failed.
Anyway I've amended it and it works a treat...thanks again !
Paresh
Tangerine,
Im starting to configure an 1841 router with similar hardware capabilities: 2 WAN interfaces and 1 LAN interface.
Would you be able to post your operational configuration for the 1721?
More Questions:
From the config shown, Im not clear on how the rtr knows how to failover to the secondary interface?
What happens when the primary interface returns?
Are you able to load-balance over both interfaces to take advantage of the bandwidth offered by both if they are both up?
TIA
